GPS - UHF all in one unit
Submitted: Monday, Feb 05, 2007 at 17:50
ThreadID: 42017 Views:2772 Replies:4 FollowUps:2
Hi, Just wondering if there is such a hand held device that has both UHF 2way radio and GPS all in one unit, and if so can any one advise of it's make, performance where to get hold of one.
Danman
Reply By: Member - Andrew (QLD) - Monday, Feb 05, 2007 at 17:57
Google "Uniden GPS205" for your answer.......though i haven't used one.
One supplier ==> www.andrewscom.com.au/site-section-02.htm
Andrew
AnswerID: 219941
Follow Up By: Ozrover - Monday, Feb 05, 2007 at 19:10
"Uniden GPS205" I bought one from DS Powerhouse the other day for $ 197.00, run out stock.
Seems to work ok, 1watt power, see how it works over time??
8 )>
FollowupID: 480546
Reply By: SA_Patrol - Monday, Feb 05, 2007 at 18:04
In the US they use a hand held called Rhino, it's not approved by ACA as it uses a different frequency.
AnswerID: 219944
Follow Up By: japmel - Monday, Feb 05, 2007 at 22:16
I think you mean Garmin Rino.
You are correct in saying they are not available in Australia. I'm hopeing they will be in the future.
japmel
FollowupID: 480605
Reply By: Muzzgit [WA] - Tuesday, Feb 06, 2007 at 23:44
I don't have one but was very interested in buying one until I found out the GPS bit of it has no way of being used for back tracking or telling your current speed or pointing in the direction you should be going because you can't punch in coordinanates and ask it to "show me the way"
They are however very handy if several people have one. Every time you transmit it tells others with the same unit what direction to go to find you, and how far away you are.
AnswerID: 220294
Reply By: Danman - Thursday, Feb 08, 2007 at 13:48
Thanks Guys' for the info will take it all in. but for power and control seems like I'll have to buy the two seperate items.
Danman
AnswerID: 220565
