Member to post photos?
Submitted: Tuesday, Feb 06, 2007 at 18:10
ThreadID: 42054 Views:2236 Replies:1 FollowUps:4
Hey guys, Do you have to be a member to be able to post photos on the forum?
cheers pips :)
Reply By: Mad Dog - Vic - Tuesday, Feb 06, 2007 at 18:20
no, just have the photo hosted somewhere and post the link to it using the syntax at the bottom of the message pane where you type the message
AnswerID: 220215
Follow Up By: pips - Tuesday, Feb 06, 2007 at 18:23
Ok thankyou Ray, although this sounds a little bit too complicated for my
computer skills O-o
FollowupID: 480770
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Feb 06, 2007 at 19:22
Its easy pips you will see at the bottom the leftat the end. The pic will then appear in the middle of the page without you taking a photo. You will see at the bottom of the window 'For Images' for the idea of the syntax. If there is a special page you can just copy the link in and it should find it for you. David really has done a great job with the Forum linkages.
If you are a member you can get a rig pic and then a number of other pictures that your posts may refer too just by clicking on Add Gallery Picture at th ebottom of our members posting window.
FollowupID: 480785
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Feb 06, 2007 at 19:24
pips, the system actually skipped over the part I put in because it had the code it expected to see for a link. Just open up a reply window and you will see it below with 'For Images"
FollowupID: 480786
Follow Up By: pips - Tuesday, Feb 06, 2007 at 21:53
Thanks John
I still dont get it so i wont
worry about it.
Thanks anyway
cheers pips :)
FollowupID: 480816
