Remote Control
Submitted: Wednesday, Feb 07, 2007 at 18:24
Des Lexic
We have a 2000 Subaroo Outback and for a little while the Remote Opening has not worked. I have changed the battery in the key a couple of times and still no better. It will work very occasionaly by unlocking and then not locking and visa versa.
I am wondering if there is a battery in the sensor unit within the car wherever that might be.
Does anyone have any clues on this problem.
Thanks in advance
Des
Reply By: Member - jeff M (SA) - Wednesday, Feb 07, 2007 at 18:46
Hi Des ,
We had a problem with our Holden keys SWMBO's set would not open the car about 2 weeks back.So I had to leave work go home and get my set of key's and hand the keys over.Then had to have new battery fitted and have it reprogramed.
Des I also want to pick your brains about the computer mapping system I need it for work so I can work out the route surveys for our wide loads.Maybe it will come in handy on 4by trips as
well ,no room to spread out maps all the time.
Do you have such a system.
Kind Regards Jeff M (SA)
220448
Follow Up By: Des Lexic - Wednesday, Feb 07, 2007 at 19:09
Yep, I'll contact you tomorrow and show you what I've got.
481028
Follow Up By: Gerhardp1 - Wednesday, Feb 07, 2007 at 23:12
What the ???
481096
Reply By: geocacher (djcache) - Wednesday, Feb 07, 2007 at 23:59
More likely to be a dry joint in the circuit board in the key from what you are describing.
There won't be a battery in the sensor unit. It runs of the big one under the bonnet.
Any chance there's a friendly electronic tech in your circle of friends?
Dave
220506
Follow Up By: Des Lexic - Thursday, Feb 08, 2007 at 11:34
Thanks Dave, I'll see if I can enlarge my circle of friends LOL
I do have a Computer nerd handy with a can of circuit cleaning spray handy. I did spray the contact side of the key but not the circuit board.
Thanks again
Des
481160
Reply By: Ozboc - Friday, Feb 09, 2007 at 08:00
sound like a ry joint -- if you have a soldering gun you can maybe just give each and every solder joint a warm up and remelt -- OR head down to jaycar and see if you can get a universal learning remote there about $50 and may help
Boc
220720
Reply By: Andrew from Vivid Adventures - Friday, Feb 09, 2007 at 08:35
Hiya Des,
Came by your place yesterday - sorry I didn't have time to stop.
Who is the ExplorOz member with the big sticker on the rear windscreen on the main road through
Berri?
Andrew.
220728
Follow Up By: Des Lexic - Sunday, Feb 11, 2007 at 18:35
G'day Andrew,
That would be member Blaze's place.
You will meet him at the Display Day. He will be displaying his
camper trailer hire biz.
Roachie and Pesty will also be there and other members as per the Members trips list.
Cya then
Des
481822
