Need advice on UHF Antenna
Submitted: Saturday, Feb 10, 2007 at 22:18
Baden
Hi all,
I'm new to this
forum and was hoping for some advice. I have just got a 2006 Nissan Navara ST-R TD and am now looking for a
UHF radio. After reading the posts and some research I have decided on a GME TX4400 and now trying to work out what antenna to get. Most of my driving will be in the mountains with some touring. I have been looking at the GME AE4018K1 and the AE4705, but would like some advice.
Thanks,
Baden.
Reply By: Bonz (Vic) - Saturday, Feb 10, 2007 at 22:24
If its mostly mountains then I would look at a 4.5dB antenna, I have the 4705 and am happy with it, but the other also looks good.
221014
Follow Up By: Member - Teabag (Queanbeyan) - Saturday, Feb 10, 2007 at 23:02
I run a 4705 for around town and when in very hilly country which is everywhere around
Canberra. When I go out into open area such as the Simpson trip etc I put a 4706 on which is a 6db aerial......Simple thing to note is lower gain aerials work better in hilly terrain and high gain aerials work better in open area....Good luck with which ever choice you go.....
481719
Reply By: Member - Doug T (W.A) - Saturday, Feb 10, 2007 at 22:35
A very wise choice of radio Baden, as for Antenna all I use is a little one that looks like a phone antenna with the coil in the center and it works like a dream
221015
Reply By: Member - Doug T (W.A) - Saturday, Feb 10, 2007 at 22:46
If you go to this link you will see an antenna on the left of the screen same as
mine and it gets out for many Ks, costs about $60 /$70
Site Link
Doug
221019
Reply By: SteveL - Sunday, Feb 11, 2007 at 01:48
In very hilly I would be using a quarter wave on the elevated base.In the High Country they work better than a 4.5dB or greater antenna.
221047
Reply By: Member - Alastair D (NSW) - Sunday, Feb 11, 2007 at 06:44
Baden,
I have the same radio & 4705 aerial and find it works
well. Whilst I know that everyone wants to get the maximum range I only want it to pick up other travellers nearby and others in my group, though we mostly travel on our own. The people that are on UHF CB routinely leave a lot to be desired (!).
alastair
221050
Reply By: Robin - Sunday, Feb 11, 2007 at 07:59
Hi Baden
The GME4400 is not to bad a radio , it one of afew we have , it does have two technical weaknesses , the CTCSS feature does not discriminate enough and second the front facing speaker tends to pole a bit .
Technically the best place for the antenna is in the middle of the roof, particularly in hilly country, anywhere else tends to give a distorted field strength pattern.
Consistent with the above the best antenna is also the cheapset.
A $13 1/4 wave whip sold at
places like DSE.
Robin Miller
221054
Reply By: Mike Harding - Sunday, Feb 11, 2007 at 08:05
Don't expect good performance from UHF CB in the High Country - it's fine when you're on top of a
hill but from the valleys you'll often be lucky to get 1 or 2km (irrespective of the antenna) so don't consider it as an
emergency radio. Probably worth buying a cheap hand held UHF CB too at least then you have the option of walking to high ground and trying to contact someone. I would also suggest the Dick Smith 4.5dB antenna.
Mike Harding
221057
Reply By: Member - Phil G (SA) - Sunday, Feb 11, 2007 at 10:59
Depends on where you mount the aerial.
A roof mount will perform best - even without gutters, there's neat ways of doing this. For a roof mount, the simple rubber stubbies ($15 aerial + $30 for base and coax) offer surprising performance. Its what I use 95% of the time. They are also unbreakable and won't be bothered by carparks, thieves, trees etc And tehy actually perform better in the very hilly country. I also have a 60cm long one with a pigtail in the middle (??Db) when I want maximum range in open country.
If bullbar mounting an aerial, you need a tall expensive one to get good performance.
221068
Reply By: luch - Sunday, Feb 11, 2007 at 14:39
Baden
Have a look at the GME site explains it all if your in mountains 4.5
Site Link
221083
Reply By: Member - Bucky (VIC) - Monday, Feb 12, 2007 at 04:55
All the above posts are spot on, but with my Navara ST-R ( bull bar mount ) I never got any real distance or clarity till I actually got a separate earth wire from the bottom of the spring base, ( on top to the bull bar ) to the earth strap, thats on the left side front,,
The difference it made was incredible
Problem was that there is too much paint and coatiings for a good earth
Bucky
221176
Follow Up By: Baden - Monday, Feb 12, 2007 at 08:17
Thanks for
the tip. No doubt you've saved me a lot of frustration and swearing try to get decent reception.
481902
Reply By: Baden - Monday, Feb 12, 2007 at 08:15
Thanks for all the replies. I've decided to go with a GME AE4018K1.
221184
