Fan For GU III Intercooler ??
Submitted: Wednesday, Feb 14, 2007 at 12:22
ThreadID: 42298 Views:7249 Replies:10 FollowUps:17
Hi all,
Just got home from a fortnight in the Territory and I have made a couple of observations.
1. The air filter was filled with bugs and crud (presumably from the newly fitted snorkel) and...
2. The intercooler was still as clean on top as it was before I left.
I did a search on here and couldn't find anything close to answering my question.
Has anyone one fitted an electric fan inside the bonnet scoop to get some air flow happening through the intercooler? Perhaps even fitting a thermo switch for automatic operation. My assumption is, if there are no bugs getting through that big opening, chances are there isn't much air either.
What are your thoughts?
Reply By: pepper2 - Wednesday, Feb 14, 2007 at 12:31
Do you have a plastic bonnet protector fitted i believe these can deflect some of the air over the intercooled scoop
AnswerID: 221634
Follow Up By: P.G. (Tas) - Wednesday, Feb 14, 2007 at 12:37
No there's no bonnet protector, just the standard alloy bull bar.
Another observation I have just made is that the sealing rubber under the bonnet is a very poor seal. It appears to only be touching about 50mm in the centre of each side, I might try sticking some closed foam around the mating surfaces to see if this makes a difference.
FollowupID: 482367
Reply By: Wayne-o - Wednesday, Feb 14, 2007 at 12:42
i have considered it mate, and someone has done it to a 3.0l....did see a pic...think it was an 8" thermo, and it did fit snuggly inside the scoop....although i was thinking of mounting one underneith to draw the air through it.....i think you right though....they get sweet fa air!!! even the hilux scoop is larger than the patrol one, but i still believe front mounting it would be a better option although much more work.
AnswerID: 221637
Reply By: downtools - Wednesday, Feb 14, 2007 at 12:50
g'day Pete,
We were advised by a well known diesel specialist to fit a fan onto the IC.
I listened to what he said and did what he suggested. That was to cut short lengths of string , about 100mm long and use some blue tack to stick them all over the bonnet. In particular, in front of and around the intercooler scoop, then go for a drive at various speeds.
I expected the string to be blown back along the bonnet with the wind but instead, the bits of string showed that there was a lot of turbulance across the bonnet and not a 'clean" stream of air over the scoop.
In short what the diesel guy said was exactly right, that is , there is next to no flow thru the IC while moving and none at slow speeds such as sand and low 4x4.
I fitted the fan and now there is a LARGE difference between the temperature of the casings at the inlet and outlet sides of the intercooler.
The fan was fitted at the same time as a tune was done so I have no way of knowing what difference, if any it made to performance. Although the GU is running much smoother and seems(seat of the pants) to have more power.
At least now I know the IC is working.
I can email you some pics if you are interested.
Nifty
AnswerID: 221638
Follow Up By: Wayne-o - Wednesday, Feb 14, 2007 at 12:53
id like to see some pics too please mate
FollowupID: 482373
Follow Up By: P.G. (Tas) - Wednesday, Feb 14, 2007 at 13:05
G'day Nifty,
Thanks for that. I would love to see your pics, my email address is petermgATbigpondDOTcom.
What sort of fan did you use, and how do you control it?
FollowupID: 482374
Follow Up By: downtools - Wednesday, Feb 14, 2007 at 13:10
An 8" thermo fan that fits snugly inside but doesn't touch the scoop.
Its wired thru a relay to the ignition. When the cars running so is the fan. I thought about switches but just kept it simple.
FollowupID: 482376
Follow Up By: downtools - Wednesday, Feb 14, 2007 at 13:13
PS.
Iv'e sent pics to your email, not sure how to post pics here. If you get them you might like to post them here?
Nifty
FollowupID: 482378
Follow Up By: fruers - Wednesday, Feb 14, 2007 at 14:17
I would be interested in seeing the pics if someone could post them. Do you remember how much it cost you to put the fan in?
FollowupID: 482393
Follow Up By: Snowy 3.0iTD - Wednesday, Feb 14, 2007 at 14:22
Nifty
I would appreciate it if you could send me the pics of your installation to snowdenj@onesteel.com
Thanks in Advance
Snowy
FollowupID: 482394
Follow Up By: P.G. (Tas) - Wednesday, Feb 14, 2007 at 16:49
Thanks for those pics Nifty. That is probably a more effecient setup than the way I was thinking of, putting it in the scoop.
I have been shopping around a found I can get an 8" Davies Craig fan kit (Part No. 0035) for about $126.
I might have a busy weekend coming up ;-)
FollowupID: 482421
Follow Up By: Member - Glenn D (NSW) - Friday, Feb 16, 2007 at 18:55
Hows it going Nifty ,
Please launch me some photos to gwdixon@tpg.com.au
Going to give the airflow test a go , a bit interested to see what happens .
Thanks .
Glenn.
FollowupID: 482952
Reply By: Patrol22 - Wednesday, Feb 14, 2007 at 12:59
Yep - the removal of the intercooler fan from GUs has always amazed me. The 1998 2.8 gu has a fan mounted under the intercooler that sucks air through. This could have been directly transferred to the 4.2 intercooled engine as the intercooler is exactly the same as the 98 2.8 minus the fan.
AnswerID: 221640
Reply By: Bob on Patrol - Wednesday, Feb 14, 2007 at 13:35
Peter,
I had consulted a reputable diesel mechanic and they suggested and ultimately installed a fan on top of the intercooler of my 2001 3.0lit patrol. They advised that in tests they has conducted that the air flow was very poor and in some circumstances air had flowed out of the air scoop instead of into it. The system they installed was not a thermo fan, instead it is always on when the ignition is on. Their reasoning was not to rely on another device to turn the fan on because by this time the intercooler was most likely too hot and the system then has to work hard to cool it down. Far better to have the fan running all the time in order to maintain a lower temp. I believe the intercooler fan is a good idea as the setup on the patrol apears not to be very effective as I believe you have discovered.
Bob on Patrol
AnswerID: 221647
Reply By: Member - Malcolm P (VIC) - Wednesday, Feb 14, 2007 at 14:50
if at all possible I too would like to see the pic's
malcolm.poes@gsjbw.com
thnks
AnswerID: 221663
Reply By: Truckster. - Wednesday, Feb 14, 2007 at 15:30
If you have a 4.2, there is not much room above, and none below...
We (me and awill4x4) have a 2.8 intercooler and fan (love u bilbo) we are working with on a project at moment. we are going with a bigger longer core and using the std end tanks. there is plenty of area to go longer towards the grill end..
but the fan from the 2.8 wont fit in there on top or below. I wouldnt be a fan of putting a fan on top it would block the natural air flow from the scoop, so in the end you would gain 0, maybe even loose some.
Tryin to get more air flowing through, if your doing 40-100k's I dont think you will get any more air flow than thru the scoop...
If your unsure, maybe an Water to Air intercooler maybe better for your application. But you need a radiator for it, pump, etc.. Great results from it, but expensive to setup.
Good luck
AnswerID: 221675
Follow Up By: P.G. (Tas) - Wednesday, Feb 14, 2007 at 16:51
Thanks for that Truckster, but at the moment there doesn't seem to be ANY natural air flow coming in.
FollowupID: 482422
Follow Up By: Truckster (Vic) - Wednesday, Feb 14, 2007 at 18:52
so you dont have a bonnet scoop?
FollowupID: 482453
Follow Up By: P.G. (Tas) - Wednesday, Feb 14, 2007 at 19:57
Hi Truckster,
I do indeed have a bonnet scoop, but in 6,500km it never even collected one bug, bit of straw, or even any dust to speak of :-o
The TJM Airtech snorkel collected nearly half a cup of crud in the air filter housing, and that's only about 1/2 the size. Just goes to show, now I have a snorkel I'll have to check the air cleaner more regularly. :-o
FollowupID: 482473
Follow Up By: Truckster (Vic) - Wednesday, Feb 14, 2007 at 22:05
Do you have one of those plastic stone guard things on the front of the bonnet??
if so, there is your problem.
FollowupID: 482514
Follow Up By: P.G. (Tas) - Thursday, Feb 15, 2007 at 05:49
Nope, no bonnet protector
FollowupID: 482557
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Feb 16, 2007 at 19:20
Guys had thought about ovalling some stainless tubing and lifting the two supports under the scoop by fitting it over the stubs of the tubes. May lift the opening and increase it by 10-20% or so. Will try it. Mine gets some stones in it and bugs too though but the fan is interesting. Need that low level pressure gauge.
FollowupID: 482958
Reply By: Boldjack - Wednesday, Feb 14, 2007 at 22:04
Hi All.
Seems to me ,that any air in contact with the IC would naturally want rise as it gets warmer (lighter) therefore going against the supposed intake flow of scoop !
Makes me think back to Torana A9X days when some people questioned the rearward facing bonnet scoop. Believe GMH engineers worked out there was good air pressure to be used from the air hitting the windscreen.
Cheers Boldjack
AnswerID: 221780
Reply By: 4X4Treker - Thursday, Feb 15, 2007 at 04:09
Peter Both myself and my mate Chaz have fitted fans on top of our intercoolers with a thermostat and relay to contol when the fan comes, if you go to Chaz'z web page you will find photo's of what we have done www.conody.com
I have found like many others that the combination of bull bar and bonnet protector the amount of air actually going in through the bonnet scoupe is almost zero but since fitting the fan I have found that the intercooler is cool and the torqu is there all the time.
Treker
AnswerID: 221814
Follow Up By: Flash - Thursday, Feb 15, 2007 at 23:10
Very professional looking job!
FollowupID: 482761
Reply By: JamieMac - Wednesday, Feb 21, 2007 at 17:40
I think you see a lot more bugs and crud in your air cleaner becuase your engine and turbo are pumping a lot more air in from a much more exposed location. Airflow at the IC will be more affected by the things in front of it and because of its position down on a surface (the bonnet). Plus the IC can shed bugs and stuff out of the scoop area where the air filter case is hopefully sealed with the snorkel fitted.
I have had plenty of bugs in mt IC area on occassions so I guess there is air getting in as well. I have a light alloy flywire over my IC (and the radiator) to keep the bugs out of it so mabe it traps more than yours does. The radiator temps have nevr been a problem despite the wire either.
Not sure if all of the effort for fitting a fan to a smallish IC will make a big difference but if it does let us all know.
JamieMac
AnswerID: 223195
Follow Up By: P.G. (Tas) - Wednesday, Feb 21, 2007 at 18:12
The more I think about it, you are right about the small size of the intercooler. I have been looking at fitting a larger one down low in the bull bar (behind the bull bar vent holes) and perhaps still fitting a small fan (just in case).
I have spent hours looking at the available space and think I can get a couple of neat 50mm aluminium pipes down beside the radiator to connect the intercooler.
I'll keep you posted.
FollowupID: 484061
