Tune it
Submitted: Wednesday, Feb 14, 2007 at 12:54
ThreadID: 42299 Views:2717 Replies:4 FollowUps:1
When we say, 'Got my deisel tuned', what exactly should we expect to be done, or what does get done to the engine to 'tune it?'
Reply By: Member - John L G - Wednesday, Feb 14, 2007 at 13:00
Not much except perhaps timing, filters and nozzles.
The large component for labour is the time taken in the office to produce a creative invoice with the greatest number of zeros to get close to 1000.
AnswerID: 221641
Reply By: Dustin - Wednesday, Feb 14, 2007 at 13:31
Hi Wayne,
I think John is talking about a service.
When you get your diesel engine tuned it usually means getting your fuel pump adjusted for optimum performace and / or efficiency. This involves getting the vehicle dynoed and adjusting the fuel flow while monitoring exhaust gas temperature to make sure egt isn't too high to damage the engine but enabling you to get the most out of your engine.
I am talking about a non computer controlled diesel enginer here.
AnswerID: 221644
Follow Up By: Member - Toytruck (SA) - Wednesday, Feb 14, 2007 at 13:43
Wayne,
agree. I used to build warships in a previus life and once while on sea trials spent the day with some dude from Germany who was sent out by the Equipment Manufacturer to "Tune", the Main Propulsion engine. Now we are not talking your average Diesel here (not gas turbine), as you could well understand BUT, you know what he monitored with all his fancy gear..........Exhaust Gas Temp. This was his basis for any adjustments he made.
Toytruck
FollowupID: 482388
Reply By: Gronk - Wednesday, Feb 14, 2007 at 13:32
If its a modern CRDI ---- NOTHING...!!! Plug in the computer and check for any fault codes ( thats IF they do that )
AnswerID: 221645
Reply By: Member - Oldplodder (QLD) - Wednesday, Feb 14, 2007 at 16:45
When I put mine in for the 100,000k service and tune up,
Injectors checked and replace/cleaned.
pump timing checked to stock setting.
glow plugs and glow circuit checked for operation.
Basic tune up, about $200.00 plus what needs replacing.
Now if I out in in to be tuned on a dyno.
New filters - air and fuel, they will insist on them to get everything right.
New injectors.
EGT hooked up and pump timing played with on the dyno to get the best performance.
You need to say if you are looking for economy or power , or a compromise.
Usually costs $600 to $800 depending on what parts need replacing like injectors.
I do the filters myself before it goes in.
AnswerID: 221691
