Anyone lookin for Air lockers?
Submitted: Thursday, Feb 15, 2007 at 00:51
ThreadID: 42332 Views:5420 Replies:5 FollowUps:33
From OL.
Appears like a really good deal to me :) with all the talk on lockers lately.
I get the latest ARB news letter (ARB 4x4 Action) emailed to me and not alot has really caught my eye until now, so how many ppl will or have taken up the lastest arb air locker offer?
not bad:
-Air Locker special offer - buy 1 get a free compressor, buy 2 get a free compressor, tyre inflation kit and Speedy Seal tyre repair kit!
http://arb.com.au/News/Australia/4x4_Action_Jan_07.pdf
Reply By: Member - Bradley- Thursday, Feb 15, 2007 at 01:41
bet its the cheapie chinese compressor that they now import and sell just for locker use.....
AnswerID: 221813
Follow Up By: Member - Jeff M (WA) - Thursday, Feb 15, 2007 at 11:49
Yeah it would be, the idiots tried to sell my friends one of those cheapo ones when he already had a pressure switch blue tounge and truck tank with an air manifold ready to hook the lockers up to... Man those guys are dumb sometimes, all they want to do is unack the box and fit, if it's anything harder or challenging than that they don't want to know about it. Not that it would have been hard, it would have been easier, but hey, I guess they don't know bleep from clay.
FollowupID: 482614
Follow Up By: wheeler - Thursday, Feb 15, 2007 at 18:34
If you had both bothered to take a look at the link that Truckster posted you would see that if you buy 1 locker you get the small compressor. If you buy 2 you get the full size compressor, an inflation kit and a tyre repair kit.
Sounds pretty good to me.
Bradley you call the small compresor a cheapy, then in your sig line your looking for cheap fuel...hmmmmmm
Jeff seems you dont know tongue from tounge
I am sure if you were ARB you wouldn't want to fit a competitors product to your diff lock either.
FollowupID: 482707
Follow Up By: Member - Jeff M (WA) - Thursday, Feb 15, 2007 at 18:43
SO SORRY for the typo..... sheesh.
They didn't have to fit a competitors product, all they had to do was plug the air line in, it was running an ARB pressure switch so the pressure was exactly the same as comming from an ARB compressor.
FollowupID: 482709
Follow Up By: Member - Bradley- Friday, Feb 16, 2007 at 01:28
Geez loosen off the girth strap on your high horse champie....
As a constant advocate for quality goods and home made if possible its not often i get called a tightarse, so thanks... dont worry im fitting lpg to the jack, but not the old venturi system, im going for sequential injection, hope thats alright by you. LOL...
Jeff - i know EXACTLY where you are coming from, i once had a discussion with arb regarding a similar situation, i was looking to fit rear locker to previous car, told them i could deliver it with a compressor already fitted (high qual/high flow unit) with a jamec 5 port manifold fed by a very high quality goyen reg. they could set the exact constant delivery pressure they wanted (unlike their set-up) . Nope it HAD to be hooked up to their compressor...... aparently it delivered some sort of magical air LOL... i left shaking my head...
FollowupID: 482793
Follow Up By: fruers - Friday, Feb 16, 2007 at 10:17
Did your mate end up getting one? I installed an arb compressor myself and ARB has no problem hooking up a locker to that. Maybe the problem is the ARB compressor reservoir which has the ports ready to take the relay, it would probably be extra work for them to install the relay into a custom setup, i.e. it doesn't fit the cookie cutter. Personally i would get a diff specialist familiar with air lockers to install it anyway.
FollowupID: 482847
Follow Up By: Member - Jeff M (WA) - Friday, Feb 16, 2007 at 10:53
When you say relay, do you mean solinoid? If so, you can just fit the solinoid in line, I have an ARB air locker solinoid fittted inline on my bluetounge so that it can re start at any pressure and it stops the air tank leaking back througth the compressor seals.
Yeah he ended up ordering it, it took them 3 weeks to get the part in, he dropped the car off they pulled his diff apart and then realised it wouldn't fit. Then they told him that his particular model didn't have a diff locker for it.... You'd think they would have worked that out sometime before. Anyway, he's since had it back to them 3 times because his diff seals keep leaking.....
So yeah, I'd recomend a diff specalist too! ;-)
FollowupID: 482852
Follow Up By: Member - Crazie (VIC) - Tuesday, Feb 20, 2007 at 09:35
have a look where the max air is made... and its one of the best around..
FollowupID: 483697
Follow Up By: Member - Bradley- Tuesday, Feb 20, 2007 at 18:18
Yeah i know Ads, but arb already have a chinese compressor line dont they? is it 2 or 3 bushranger models including the max air, so why bastardise the great rep of the ARB compressors by bringing in an inferior unit and brand it the same?
Personally id offer the top spec lockers/combi with a great warranty, and the option of lockers/cheapie with standard 12 month warry..
just my opinion.
cheers Brad.
FollowupID: 483793
Reply By: Tyreplus4x4 - Thursday, Feb 15, 2007 at 07:44
why so negative it could be a good deal.
AnswerID: 221823
Reply By: Member - Willie , Epping .Syd. - Thursday, Feb 15, 2007 at 10:18
Truckster ,
Can you recommend a system that you can put in your air hose line , that tells you the pressure like the ones in the service station ? I guess it would lighter than the service station ones .
I am getting sick of taking the hose off , putting the guage on , putting the hose on................................................
Thanks ,
Willie .
AnswerID: 221848
Follow Up By: Truckster. - Thursday, Feb 15, 2007 at 10:27
Repco/autobarn/supercheap all sell them things with gauges on.. but how accurate. suppose as good as any chinese pressure gauge.
Just fit click lock type fittings same as servo on compressor and hoses.
FollowupID: 482592
Follow Up By: Member - Willie , Epping .Syd. - Thursday, Feb 15, 2007 at 10:39
Thanks . I might check some of the companies like ENZED etc for a better quality unit .
FollowupID: 482595
Follow Up By: Member - Jeff M (WA) - Thursday, Feb 15, 2007 at 11:47
I have a guage on the dash, but unless you turn the compressor off to check the pressure, the pressure will not be accurate as it is effected by the compressor's own pressure. ie My guage is about 10psi out unless I turn the compressor off. The easiest way is to just use the timer on your watch. I know that about 3 mins get's me back to a decent pressure, then I just top them up when I get home or if on a long trip at the next servo.
FollowupID: 482613
Follow Up By: Taz & Milka-Queanbeyan - Thursday, Feb 15, 2007 at 14:48
Willie,
If you find a good quality one that doesn't cost an arm and a leg could you let me know please. I have a twin tongue with a small tank an airlines running to front and rear bars. I would like to fit a decent guage into the system to keep an eye on the pressure.
I am also considering a rear locker.
Cheers ... Taz
FollowupID: 482645
Follow Up By: SA_Patrol - Thursday, Feb 15, 2007 at 15:01
I got one of them blue footpumps wit a gauge on it, works good too. :-)
FollowupID: 482648
Follow Up By: Waynepd (NSW) - Friday, Feb 16, 2007 at 20:57
Willie I have the Max Air with the inline gauge.
I have found that if you turn the compressor off it reads very accurately. I compared it to my tyre gauge and they were spot on with each other. I guess this will change as the compressor ages but for now its right.
Not sure if you can get replacement gauges for the Max Air....
FollowupID: 482990
Follow Up By: Member - Willie , Epping .Syd. - Saturday, Feb 17, 2007 at 18:42
Wayne ,
There is no way that I want to go and turn the compressor off to check the gauge . It would be easier to check the pressure with a hand gauge .
What I need is an ON/OFF trigger , like the service station air guns , but in a more lightweight design .
I will post if I find anything .
Thanks all ,
Willie .
FollowupID: 483175
Follow Up By: Waynepd (NSW) - Saturday, Feb 17, 2007 at 21:47
Fair enough Willie,
Mine isn't vehicle-mounted so the compressor is right next to the tyre when inflating it. Simple matter of switching off and reading the gauge.
The garage type gauge might damage a small compressor if its left running when changing over to the next tyre and the trigger is shut off.
From my training at work where I run rather large compressors driven by 2700kpa steam turbines or 63kV Electric motors i have been taught that compressors are a positive displacement device that don't like to have their flow stopped while running.
Don't know if our small devices have pressure cutouts like garage ones, do they?
I am not comfortable depending on overpressure devices in normal operating prefer them as emergency use only....but that's just me maybe.
FollowupID: 483197
Follow Up By: Member - Willie , Epping .Syd. - Saturday, Feb 17, 2007 at 22:06
Wayne ,
That is a good point . I will ring ARB and ask them about the compressor .
Look at the one I found here www.air-up.com/products.html
It looks perfect if it is OK to use it on the compressor .
Thanks ,
Willie .
FollowupID: 483204
Follow Up By: Waynepd (NSW) - Saturday, Feb 17, 2007 at 22:21
Willie i have used this mob before,
Site Link
prices are good and quality seems ok.
I bought some welding masks from them.
FollowupID: 483207
Reply By: V8Diesel - Thursday, Feb 15, 2007 at 11:06
OT - you've been a bit quiet of late Truckie, when are you going to liven this place up a bit?
AnswerID: 221853
Follow Up By: Truckster. - Thursday, Feb 15, 2007 at 13:02
Lots of inbreds here now, its hard to even get a smile out of anyone.
none of them would even understand the shoelace thread anymore...
FollowupID: 482631
Follow Up By: Alloy c/t - Thursday, Feb 15, 2007 at 16:28
Whats a "shoelace" ?????? 9 out of 10 kids under 18 could not tie a shoelace properly as all their shoes have velcro. LOL
FollowupID: 482663
Follow Up By: Pajman Pete (SA) - Friday, Feb 16, 2007 at 08:25
Truckster,
I missed the shoe lace thread, I'm still wondering what it was about and you keep bringing it up to taunt me!
Pete
FollowupID: 482821
Reply By: Andrew from Vivid Adventures - Thursday, Feb 15, 2007 at 11:33
So Truckster - you say "From OL" ... what do you mean? OL are sending you ARB's newsletter?
AnswerID: 221859
Follow Up By: Truckster. - Thursday, Feb 15, 2007 at 13:01
yea, I regularly send emails from business'.. do it daily actually hourly
FollowupID: 482630
Follow Up By: Andrew from Vivid Adventures - Thursday, Feb 15, 2007 at 13:04
I'm still lost ... was just wondering whether your original post was Opposite Lock saying to you that air lockers are a good deal at ARB at the moment?
Did I get it right?
FollowupID: 482632
Follow Up By: Member - John (Vic) - Thursday, Feb 15, 2007 at 13:43
Andrew I think he means OverLander Forum???
FollowupID: 482635
Follow Up By: Andrew from Vivid Adventures - Thursday, Feb 15, 2007 at 13:46
Oh right ... I think OL Forum needs to sue Opposite Lock for having a misleading and deceptive name.
Thanks Truckster.
Andrew.
FollowupID: 482637
Follow Up By: Truckster. - Thursday, Feb 15, 2007 at 15:53
Overlander?? My god no. Largest bunch of wankers and wannabees on the planet!
Outerlimits.
FollowupID: 482658
Follow Up By: Wisebyname - Thursday, Feb 15, 2007 at 17:00
You won't find a bunch of wankers or wannabees on outers,,, nnnnnoooooooooo LOL
FollowupID: 482670
Follow Up By: Bonz (Vic) - Thursday, Feb 15, 2007 at 17:58
OL=Outer Limits
Shoelace=Forum folklore, one has been heard to say of the great shoelace thread that it is a figment of the imagination of the "oldies" of the forum, so steeped in mysticism and hearsay that it was cooked up to promote 3.0L Patrols. Upon mentioning that an audible inhalation of air was experienced. Awe followed, along with a small puppy.
FollowupID: 482686
Follow Up By: Member - John (Vic) - Thursday, Feb 15, 2007 at 18:50
OL = Outer Limits...Over Lander...All the same to me??
FollowupID: 482712
Follow Up By: Member - Bill F (VIC) - Thursday, Feb 15, 2007 at 18:52
The Old shoelace thread
SEE the first >>>> Truckster (Vic) posted about Calling all SHOE owners - (PostID: 28300)
BillF
FollowupID: 482714
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Feb 16, 2007 at 09:54
Hi Bill, I always look for that Troopy around and remember Bonz on the UHF "all I see in the mirror is a swaying block of flats" Hope yopu guys are well anyway.
Here is the link for shoelaces. Site Link Credit to David and Michelle it is still up!
FollowupID: 482842
Follow Up By: Bonz (Vic) - Friday, Feb 16, 2007 at 21:00
John this is A link for some shoelace references, but not THE shoelace thread.
THE shoelace thread had upwards of 4000 hits and hundreds of responses all in under a day, alas is went the way of socks when I wash.
Thanx for the reminisce
FollowupID: 482991
Follow Up By: Truckster (Vic) - Friday, Feb 16, 2007 at 21:24
It was too good to keep... for some reason.. they kept the s hit one.
FollowupID: 482996
