Steering Problem
Submitted: Saturday, Feb 17, 2007 at 20:50
MAl & Sue
I have a 92 cruiser and after hitting small bumps on the highway I experienced severe vibration in the steering.Almost like
tank slap on a motor bike.What can be the problem?
Reply By: Member - extfilm (NSW) - Saturday, Feb 17, 2007 at 20:59
probably wheel balance
222351
Reply By: Graham & Lynne - Saturday, Feb 17, 2007 at 21:09
if you have lifted
suspension need to fit new offset bushes to trailing arms to rectify change in caster angle
222352
Reply By: udm - Saturday, Feb 17, 2007 at 21:27
what u r experiencing is usually called death wobbles... how may kms on the car? Youll find it on patrols and cruiser. nobody has actually found the fix, u pretty much have to go through replacing bushes, checking steering components, etc
222355
Follow Up By: MAl & Sue - Saturday, Feb 17, 2007 at 23:12
145,000 k ,
483231
Reply By: Eric Experience - Saturday, Feb 17, 2007 at 21:37
Mal.
If the vehicle has done a lot of K's it will be lose in the swivel bearings and wheel bearings. The swivel bearings [King pins] are normally set up with a bit of preload to stop them rattling around on rough roads. If you want to fix it properly, strip down each swivel housing and fit new bearings. While your at it test the steering joints and adjust/replace the wheel bearings. Eric
222357
Reply By: Willem - Saturday, Feb 17, 2007 at 21:40
Probably a rooted steering damper
222358
Reply By: Middle Jeff - Saturday, Feb 17, 2007 at 21:49
All of the above, plus check tie rods ( any movement and they are shot ) also shocks. Realy just get under it and try to move things also jack it up and grab the
wheels and move them side to side and top to bottom, the slightest movement is magnified on road.
Have fun
Craig
222359
Reply By: Dave198 - Sunday, Feb 18, 2007 at 00:28
Think I would do what extfilm suggests and do a wheel balance first up.
Dave
222382
Reply By: Member - Douglas M (SA) - Sunday, Feb 18, 2007 at 18:18
Hi Mal & Sue,
I had exactly the same symptoms after converting to part time 4wd. The first time it happened it was so severe that I thought That I'd had a blowout!
I fitted a return to center steering damper, had the off-set bushes fitted, (It's had a 2" lift) and had the wheel alignment and
suspension checked ( by professional
suspension people) and found nothing wrong. This work only reduced the severity of the problem but it did not disappear altogether. Reply 4, "Eric Experience" seems to be on the right track and this will be my next move. Please lt me know how you get on.
Mine is a 1990 model with what I
I think is about 300,000 K's
Doug
222496
Follow Up By: MAl & Sue - Sunday, Feb 18, 2007 at 18:49
I had several test drives before buying and no problems.I have since been told that the tyre can get out of round with the steel in the tyre shifting???.I do rember having new tyres fitted to a Hilux and the tyre not being able to be balanced to the rim.-Irritating.I will submit results.
483345
Reply By: GQ_TUFF - Sunday, Feb 18, 2007 at 22:31
This is from a Patrol point of view...This may sound like a funny answer, but I have had the death wobbles at different levels, once after driving through some mild mud I got back on the black top and the car felt like it was gunna part company with the chassie at around 80-90 kp/h....I was thinking the worst of course, I got home and gave all around the front discs, coils, disc backing plate and the inside side of the rims a really good flushing out and wobbles went but I must add there was no visible mud there but I did get a bit of sediment out, now as others have said small movements are magnified on the road so if you have say 500 grams of dirt stuffed up there and hit a bump it would be like having a 5 kg lump of extra weight affecting it. Now I once heard of another patrol driver say that
water can get stuck between the backing plate and disc and cause a out of balence feel as
well.......Best of luck to you I NEVER solved it in my GQ......and my GU does it to a certain extent (very mild) but it does not annoy me YET!!! lol
Cheers Stefan
222577
