electric brake control
Submitted: Saturday, Feb 24, 2007 at 15:14
ThreadID: 42651 Views:2566 Replies:6 FollowUps:9
i have purchased a 4 wheel trailer (turn table) 12'x7' 4500kg gross and i need a brake control unit for the wagon is there a brand that suits my particular application.
MATTIE
Reply By: DIO - Saturday, Feb 24, 2007 at 16:28
With that sort of weight, you might need to check with authoriries in your State to ascertain legislative requirements regarding brakes, controller/control method etc. Probably the best place to start if you want to get it right.
AnswerID: 223737
Reply By: Member -Dodger - Saturday, Feb 24, 2007 at 16:48
If you need an elec brake controller you cannot get better than a Tekonsha Prodigy. A little exy but the best IMHO.
Cheers Dodg.
AnswerID: 223741
Follow Up By: Leroy - Saturday, Feb 24, 2007 at 17:23
exy? They're only like $150! If's that's a lot to pay for something that could save your life then i think it's cheap.
Leroy
FollowupID: 484621
Reply By: RedGibber - Saturday, Feb 24, 2007 at 18:04
I'm with Dodg Mattie!! Tekonsha Prodigy is the go!!
BTW, waddya towing the trailer with??
Red
AnswerID: 223753
Follow Up By: mattie - Saturday, Feb 24, 2007 at 19:06
thanks for the replies some one will be picking it up and they will not have a brake control unit, i am guessing that the trailer brakes will only work off the seven pin plug with the extra wires hooked up other than just the brake, tail lights and the right/left indicators?
are the tekonsha prodigy units complicated to fit?
MATTIE
FollowupID: 484639
Follow Up By: Leroy - Saturday, Feb 24, 2007 at 20:08
very easy to install. go to the website and download the instuctions.
Leroy
FollowupID: 484647
Follow Up By: mattie - Saturday, Feb 24, 2007 at 21:45
i will check that www.
we are towing it with a nissan wagon
FollowupID: 484662
Follow Up By: SA_Patrol - Saturday, Feb 24, 2007 at 22:48
the max you could tow behind your nissan wagon would be 3500kgs you'll also need brakeaway brakes on your trailer.
FollowupID: 484670
Follow Up By: mattie - Sunday, Feb 25, 2007 at 08:24
i checked out the www. it looks very simple to install thank u.
up what weight can u tow without the break away system?
FollowupID: 484684
Follow Up By: SA_Patrol - Sunday, Feb 25, 2007 at 22:58
2000kgs
FollowupID: 484819
Follow Up By: mattie - Monday, Feb 26, 2007 at 07:09
thank u
FollowupID: 484831
Reply By: dj Patrol - Sunday, Feb 25, 2007 at 20:43
Go for the Prodigty just got one for $168 .
djpatrol
AnswerID: 223936
Reply By: mattie - Sunday, Feb 25, 2007 at 22:02
i was on ebay and there are quite a few for less than $170+ freight, i assume that is a reasonable price? I will check monday.
MATTIE
AnswerID: 223950
Reply By: Member - eerfree(QLD) - Sunday, Feb 25, 2007 at 23:21
Mattie
Am I correct in thinking that what you have purchased is basically a Two Axle Dog Trailer?
If so are both axles braked, again if so, you will need to be extremely careful with the setting up of the individual sets of brakes.
As far as I know (and I am NOT an expert) the Prodigy is designed to operate Sets of axles whereas you are connecting it to two seperate axles!
If I have got this wrong then I apologise, it is getting late- if I am right then Thank me...
eerfree
AnswerID: 223966
Follow Up By: mattie - Monday, Feb 26, 2007 at 07:14
yes your assumptions are correct, but how is setting up a tandem trailer with 2 braked axels different to setting up a dog trailer with a braked axel at each end of the trailer instead?
MATTIE
FollowupID: 484832
