Coromal Offroad Camper Trailers
Submitted: Tuesday, Feb 27, 2007 at 17:27
WA 1968
Well, we finally picked up the Camper Trailer yesterday and have giving it the run down in the back yard at the moment. One question I never asked before on the forums was: How Offroad are these Offroad Camper Trailers. I'd be really interested to hear the history of those who have similar type set ups to ours i.e. Wind up camper trailers (Coromal, Jayco, Goldstream etc etc)
I guess end of the day common sense prevails as to where you take it, and also the individual drivers experience as
West Australian Members reponses would be of great interested to know what tracks you have taken yours on.
Ash
WA 1968
Reply By: Member - Effie C (ACT) - Tuesday, Feb 27, 2007 at 18:59
Off-road in name only, read Coromals fine print warranty void if taken really off road. Good for formed gravel tracks etc.. Yes we do own a Coromal shiloutte and we find it great but no warranty
224403
Follow Up By: WA 1968 - Tuesday, Feb 27, 2007 at 23:10
Thanks Effie. Interesting to see someone reads teh fine print. Have no real plans to take on heavy off road tracks, just interested to see where people have taken theirs. What model Silhouette did you purchase?
485386
Follow Up By: Member - Effie C (ACT) - Wednesday, Feb 28, 2007 at 08:57
390-1 2003 model, don't think I would take it on any major desert treks (they are really too heavy for that sort of thing), but for the odd foray into the national parks dirt roads etc.. they would be fine.
It is amazing how far our predecessor's got with just a two wheel drive Holden / chev / ford and a standard plywood caravan, just took longer as you drive to suit the conditions at hand.
485437
Reply By: Muzzgit [WA] - Wednesday, Feb 28, 2007 at 00:24
We spent a bit of time investigating the purchase of one of them, as opposed to our Jayco Outback camper.
They seem
well made, a little low to the ground for heavy sand (the drawbar can act like a plough) and should have all the dust sealing qualities of a collander, just like the Jayco's. te he
They don't take kindly to the heavy stuff like desert tracks or lots of
water and bulldust is a curse.
We have taken Jayco's through the corrugations and dust of Millstream NP and Karijini NP, and minus the dust getting in, not much of a drama.
A screen to stop rocks hitting the camper and then smashing the back window on the car is always a good idea, and get underneath and make sure all the electrical wiring is properly protected. Corrugations can cause sharp edges to wear thru and short out stuff when you least need it
224491
Reply By: Member - Fred L (NSW) - Wednesday, Feb 28, 2007 at 16:32
G'day Ash
I have had a Coromal 390 for about a year and have been on some pretty rough tracks without any major problems. Just take it slowly and I'd say you can go most
places. Only issues I would mention are: As already stated dust. This has been covered in previous postings. Tape over the air vents around the fridge. Also. going over some fairly steep bumpy hills I found the towbar drags into the ground. I ahve been told that the solution that partly helps is to turn the tow bar (treg) 180 degrees so it sits higher. It gets very hot in the camper on a hot day so a 12v fan is a must. Only other issue i have and I am going to post today is that the
water tanks (have 2 of them) run out of
water so I need some sort of
water gauge. Other than that I can set it up in about 15 minutes and and I really enjoy the fact that I can take it just about anywhere and not be too bothered about the terrain. I bought it to enjoy off the beaten tracks so I am not bothered about warranties. By the way I have a GU 3.0L. Cheers and enjoy.
FredL
224591
Follow Up By: WA 1968 - Wednesday, Feb 28, 2007 at 21:18
Thanks Fred. i'm not too fussed on warranties also. If I have taken my vehicle or in this case van somewhere i shouldn't...then who's fault is it....usually
mine.
Like the idea or turning the treg 180 degrees. Mostly i am looking at softish sand tracks and gravel corrugated roads.
485579
Follow Up By: Member - Effie C (ACT) - Wednesday, Feb 28, 2007 at 22:09
Evening Fred L
Your second
water tank, I assume it is mounted behind the axle, any idea as to much this has affected your ball weight? was thinking of fitting second
tank to try and reduce ball weight a bit, currently 145 odd kg, weighs the tail of car down a bit.
Trying to work out what you mean by rotating the trek by 180 degrees?
TIA
John M
485593
Follow Up By: WA 1968 - Wednesday, Feb 28, 2007 at 22:52
I'm thinking turning the towball tongue over so the height of the hitch is higher..my guess anyway
485603
Follow Up By: Member - Effie C (ACT) - Thursday, Mar 01, 2007 at 08:04
Must be a Nissian thing, if I turn the towball tongue over it sits closer to the ground.
485652
Reply By: Member - Fred L (NSW) - Thursday, Mar 01, 2007 at 09:42
Hi Effie, Don't know what the ball weight is but the tanks were installed by Coromal. I just like to see the CT dead set horizontal as
well as the Patrol.
The problems I have is when go in into a dip at about 30 degrees and coming out at about 30 degrees plus. This is a bit of thing with the Nissan anyway. Turning the towball tongue would help a lot but this would be the only time I would need to. I will try it that way under normal conditions & see how it goes.
By the way Ash - another essential not mentioned is electric brakes.
224724
Follow Up By: Member - Effie C (ACT) - Thursday, Mar 01, 2007 at 13:17
Thanks Fred
485707
Follow Up By: Member - Kingsley N (SA) - Thursday, Mar 01, 2007 at 23:09
!MPG:4!
Mine sits nice and straight with OME HD
suspension upgrade from ARB. My Coromal has a sticker on the hitch warning that it must be only be used in the upright position!
The van is good. We have had it on a lot of the long corrugated and rough tracks around SA (
Oodnadatta,
Birdsville,
Arkaroola etc) and had no problems. We have camped in heavy rain in Qld and we had to add plastic to the sleeping areas to prevent seepage onto the bedding. After two years and about 15000 KM towing it is going fine basically. Let's face it you won't be able to tow it across the Simpson, but you can have lots of fun in the outback using rough roads that you wouldn't take a caravan on. It is heaps more comfortable than a camper trailer (KK and similar).
Kingo
485796
Follow Up By: Member - Fred L (NSW) - Friday, Mar 02, 2007 at 09:51
Hi Kingo,
We also added plastic to the bedding - good idea.
A question though.
How did the OME HD effect the ride. Did you find it smoother/rougher, easier to handle the vehicle on good roads/off road.
Appreciate your comments
Fred
485860
Follow Up By: Member - Kingsley N (SA) - Friday, Mar 02, 2007 at 11:13
Fred,
The OME
suspension is just great. I finished up with about 50mm lift (unladen). It was done by ARB and they look at your maximum loadings.
The springs are "progressive", a modification to the sway bay on the front is included. The cost was about $1300. I have had it back twice due to a "sproing" noise on the front LHS. It was due to a burr on the bottom of the spring interferring with the mounting point. It is OK now. The overall effect is for a better handling vehicle. It is not too firm. In fact my brother thought it was softer when he rode in it compared with his only other ride when on original springs and brand new. It handles winding hills roads very
well, but is obviously not a Porsche! I am very happy.
Kingo
485878
Follow Up By: Member - Effie C (ACT) - Friday, Mar 02, 2007 at 11:21
Kingsley
Any chance of some close up pictures of your front stoneguard?
485879
Follow Up By: Member - Kingsley N (SA) - Friday, Mar 02, 2007 at 16:22
Effie, I have just added some close ups of the stone guard to my members rig and profile, so you can click on and see. It was a locally sourced and manufactured accessory available when I purchased my rig from Coromal
Adelaide. The rframe is simply square tubing and the rust proofing is non existent. I should get it dipped. The guard does its job
well. I have no stone chips on the back of the vehicle and I am comfortable about no stones getting up to the rear glass. The rake of the guard is just about right but I have broken a taillight when reversing and turning. Also you can only open the tailgate big door if the car and van are in line or turned slightly left.
Kingo
485920
Follow Up By: WA 1968 - Monday, Mar 05, 2007 at 23:55
Kingo,
Read with interest your comment about the plastic on the bedding. Not exactly sure what you mean. To quote Pauline Hanson : "Please explain".
Even if you could update some photos in your members rig and profile to explain what you mean.
Also, anyone found the original Coromal mattresses a little hard and what have others done to get over this.
Ash
486455
Follow Up By: Member - Fred L (NSW) - Wednesday, Mar 07, 2007 at 09:38
G'day Ash, back after being off for a few days with the 'logie'.
We have a plastic cover (it is actually not plastic but that stuff that is waterproof that they make jackets out of) that we put over the bedding in cases when packing up and all the canvases are wet. Saves us having to bother with any damp spots when setting up
camp that night.
Also, what I do most times if not staying in one spot is instead of using the poles on the flysheets over the beds I just use a couple of jockey straps and secure the flys to the posts on which the beds rest. Very quick & easy for overnighting but when v hot does not let much air between the canvas roof and the fly.
With the
water tanks I have 2 tanks sitting side by side but both forward of the axle. Interesting!!! Would certainly increase the ball weight when full. The tanks are simply connected with a pipe between the two - effectively making it one
tank. Might consider changing this so that if I lose the
water from one
tank I might still have a second
tank - rather than losing the lot.
Great to see you guys sharing ideas about the Cormals. Here on the E coast I don't see too many.
Cheers Fred
486674
Follow Up By: Member - Kingsley N (SA) - Friday, Mar 09, 2007 at 20:38
WA 1968,
Sorry about the late reply. We have been away
camping for a few days (Port Vincent,
Yorke Peninsula; windy, very windy; not many blueys).
The problem with wet canvas is common to many campers, I believe. The Coromal has a waterproof shiny black section stitched in about 250mm high on the inside around the bed ends. Unfortunately this is not quite high enough and our bedding (doonahs and pillows) tends to touch the canvas walls above the plastic and the moisture wicks onto the bedding. To correct this I cut several lengths of flexible sheeting that I got from a "rubber shop" (similar to Clarkson's). I made sure that they were about 320mm high and long enough to go completely around the mattresses on the three sides where they touch the canvas. We just slip them in so that they stand up between the mattress and the canvas wall. It works a treat and we only use them if rain is expected. When not in use they roll up and are stored in a locker. The strips were cut from a large sheet then stuck together with tape and measure approx 320mm X 5000mm in total (depending on bed).
We also have some sheet plastic handy under the mattresses to cover the portion of the large bed that is exposed in the doorway. It can get wet in driving rain when setting up or down. The smaller bed is not affected. One big advantage of the Coromal is that the canvas bed ends are permanently attached to the bed slides, covering the mattress while you set up.
We also have the optional flies on the bed ends and the rather good side awning. We wrap the bed ends with the flies rather than setting up with poles and ropes (see another post above). We can look a bit like Bullen's Circus if we set the whole show up with the poles and ropes. We have done that when staying on a bush site for a few days or more.
Kingo
487255
Follow Up By: Member - Effie C (ACT) - Friday, Mar 09, 2007 at 21:35
Kingo / Fred
Just one more question, what size tyres have coromal fitted to your campers, just wondering if different sizes where fitted to suit different tow vehicles.
487274
Follow Up By: Member - Kingsley N (SA) - Friday, Mar 09, 2007 at 22:40
Fred,
Mine came fitted with new Sunraysia style steel 16 inch
wheels (six stud) and Bridgestone Dueller 265/75 R16 rubber. I did not think at the time to match them to my vehicle. I am informed that this pattern will suit Landcruiser 100, but do not fit my GU Patrol due to a different hub offset. I haven't tried fitting one to the Patrol. I must do that one day!
Kingo
487298
Follow Up By: WA 1968 - Saturday, Mar 10, 2007 at 19:45
Thanks Kingo for your lengthy please explain. Makes a lot of sense now. Do you find the mattresses a little hard?
487441
Follow Up By: Member - Kingsley N (SA) - Sunday, Mar 11, 2007 at 16:43
WA 1968,
My Pleasure. My wife and I have not had a problem with the foam mattresses. They are a bit firm but I would rather have that than a hard spot for your hip. When tenting we use the self inflating "4WD" Jumbo Mats and they are much the same. I know that Coromal offer an innerspring for the large bed, but I reckon it would not be that great on the hard base, and if I remember rightly it was an expensive option.
Kingo
487582
Reply By: WA 1968 - Thursday, Mar 01, 2007 at 22:56
Thanks Fred. They wouldn't let me leave the dealership unless i had Electric Brakes installed. I think it must be law.
224828
Reply By: paul.as - Friday, Mar 02, 2007 at 11:30
WA 1968,
Had our Coromal for 12 months, bought it second hand. And its been great.
Off road we have been along the Gibb, but thats really only rough dirt road, although crossing the pentecost and other rivers along the way, we were certainly glad to have the extra height.
Been into
Lucky Bay, between
Kalbarri &
Port Gregory and camped in the back of the
sand dunes.
ALso been to other caravan parks up and down the west coast.
We only have one
water tank, which sits behind the axle, although i can see that there is room for another in front. So may explore the option of putting the second one in.
Does anyone know what the deal is with plumbing it in?
Paul
224898
Reply By: Im.away - Tuesday, Mar 06, 2007 at 08:37
One thing I do know is that if you take it up the
Broome -
Cape Leveque Rd, take it really easy. The one we saw smashed to a million pieces last August clearly didn't take it easy enough.
225570
