hard mattress in c/t
Submitted: Wednesday, Feb 28, 2007 at 19:09
crocket
Has any body tried a layer of that egg carton shaped foam on top of a inner spring mattress to soften it ? I noticed it in CK. rubber in green & yellow colours, green being the thicker one. I wandering how hot it might get in summer? crocket
Reply By: Mr Fawlty - Wednesday, Feb 28, 2007 at 19:18
I have a piece of the high density stuff on the top of our mattress, makes things marginally more cumfortable but in hotter weather we have noticed that we stay cooler, must let air curculate I guess...
224625
Reply By: On Patrol (Aust.) - Wednesday, Feb 28, 2007 at 19:18
crocket
We used the soft stuff on a rock hard mattress in our old van with great success and sleep. We also had a good quality mattress protector on top of the foam to "insulate" it. No problems even on warmest nights. PS we put the knobly bits UP.
Colin.
224626
Reply By: Notso - Wednesday, Feb 28, 2007 at 19:19
Yep, works good,
Use the heavier one, doesn't get hot I used it all over the Kimberlys in a CT no probs
224627
Reply By: Brew69(SA) - Wednesday, Feb 28, 2007 at 19:27
Do whatever it takes to make the bed in the camper super comfy. Otherwise you may as
well use a tent.
224630
Reply By: Motherhen - Wednesday, Feb 28, 2007 at 19:32
Good stuff crocket. When we bought out caravan, previous owner gave us her 'eggshell' mattress overlay as it was QS and too big for their home bed. It is very comfortable and keeps us cool. My husband finds his bad back much better when sleeping in the caravan than at home (i keep telling him we should be out on the road).
224632
Reply By: Member - John R (NSW) - Wednesday, Feb 28, 2007 at 19:46
Gidday Crocket. The foam shouldn't get hotter than the innerspring if it's open celled foam. Foam is colour coded according to it's density (hardness or
resilience). Brown is usually the firmest, followed by green, yellow, white, purple, blue, and another white.
Yellow is pretty firm, but with the egg carton pattern it should reduce pressure points (which make it uncomfortable). It's a good compromise. I think green is a bit firm, even if it's under the yellow. Personally, I wouldn't bother with the green.
Just put a mattress protector over it and it'll be fine.
224634
Reply By: Member - Uncle (NSW) - Wednesday, Feb 28, 2007 at 19:48
Yes, top marks from us also on the eggshell. We have a high density foamie, then the eggshell, then the lambs wool underlay. Hot or cold climates it is extremely comfy.
224637
Reply By: Member - Matt M (ACT) - Wednesday, Feb 28, 2007 at 20:06
Another vote for it.
224640
Reply By: Kiwi Kia - Wednesday, Feb 28, 2007 at 20:06
I did not know the significance of the diff colours. I came across it at an old folks home, they recomend it for the oldies to avoid sores from pressure points. My mother swears by it for comfort (yellow).
224641
Follow Up By: where2go - Thursday, Mar 01, 2007 at 21:05
You should try Tempur overlays. It's an open celled foam and it's also temperature sensitive so it actually moulds to your shape and stays firm in other areas with less pressure. I think they also do
seat cushions and stuff. www.tempur.com.au
A friend got a mattress from them made to his exact size that he wanted for his caravan after buying one from home and loving it.
485768
Reply By: Batboy - Wednesday, Feb 28, 2007 at 21:15
Oh Yeah tis good. Colours denotes density Yellow = med, Green =High I think there is another colour above green then you can get Latex and about $200.00
224653
Follow Up By: Member - John R (NSW) - Thursday, Mar 01, 2007 at 08:47
Brown used to be the highest density in polyurethanes (F80), Green = F70, Yellow = F60, White = F50 and so on.
F80 was almost like solid rubber (very few cells). I used to make the stuff a loooong time ago. (One of the most health threatening occupations known to man!) We made very little F80 as very few companies had any use for it.
I can't remember how the numbers worked......
485664
Reply By: Member - JohnR (Vic)&Moses - Wednesday, Feb 28, 2007 at 21:26
crocket, I have slept a few nights on it. Yes, I agree with the others on comfort but believe it inhibits movement like rolling over in bed. I guess it has be be considered along with the doonah or whatever as to wether you get too hot. They can't be considered in isolation I believe.
224658
Reply By: Bros 1 - Wednesday, Feb 28, 2007 at 21:27
Crocket,
Well okay everyone, where do you get this wonder of our ages egg shell mattress thingo. Got a C/T with a 6 inch foam mattress at present.
Bros.
224659
Follow Up By: Member - Robyn J (QLD) - Wednesday, Feb 28, 2007 at 22:01
You can get them from Pillow Talk in Queensland. Brought one last xmas because the new high density matress was too hard to sleep on. Only problem was having to pull off the bed before folding the Jayco dove up as it would have been too thick for the roof to come down. Ok for us as we usally only use the Jayco when sitting in the one spot on xmas holidays and use the camper for other trips during the year.
Jenkie
485591
Follow Up By: spliney - Thursday, Mar 01, 2007 at 07:50
Or Clark Rubber
Spliney
485648
Follow Up By: Member - John R (NSW) - Thursday, Mar 01, 2007 at 08:39
We bought ours from Spotlight (Auburn).
485660
Reply By: Member - Brian (Gold Coast) - Wednesday, Feb 28, 2007 at 22:01
Another vote for it... ours is yellow and damn comfy!!!!!
Brian
224670
Reply By: Member - Pesty (SA) - Wednesday, Feb 28, 2007 at 22:10
Yes good choice,we have one on our bed at home, in the camper, and the swag with a lambswool magnetic overlay on top.
Dont care how bulky it is, you need to be comfortable to enjoy being away.
Cheers pesty
224673
Reply By: Bros 1 - Wednesday, Feb 28, 2007 at 22:25
Robyn J,
Thanks for the outlet.
Bros.
224675
Reply By: 3F62 - Thursday, Mar 01, 2007 at 08:15
We have just gone from a High density foam Q/S with an "eggshell" in the camper to a 10cm self inflating.......we found it so much better we didnt need the eggshell so we have placed the old eggshell upside down under the new mattress to hopefully allow more air to circulate under the mattress.
224711
Reply By: Scoey (QLD) - Thursday, Mar 01, 2007 at 14:40
We put a yellow egshell one (Dunlop Brand from memory) on a very dead innerspring mattress and it was a massive improvement. I would liken it to sleeping on a normal innerspring as opposed to a pillow-top innerspring.
Definately get it - the bed only gets comfyer! ;-)
Scoey!
224763
Reply By: Steve63 - Thursday, Mar 01, 2007 at 16:34
Crocket,
Yellow egg shell foam was used in hospitals extensively in an attempt to decrease the occurance of pressure sores. Put the pointy bits up. It certainly improves the comfort level. One of the claims was that more air circulated, so skin stayed drier and deceased the occurance of the skin breaking down.
Steve
224768
Reply By: crocket - Wednesday, Mar 07, 2007 at 21:15
Thanks for all the good info on foam, mellow yellow is the go.cheers Crocket.
225930
