IPF 900XS Light wiring insulation
Submitted: Wednesday, Feb 28, 2007 at 20:23
ThreadID: 42803 Views:2081 Replies:3 FollowUps:3
I have installed my 900xs that are waterproof.
The lights are connected with 'click in' connectors. I would assume that as these are not waterproof (simple lug in connextors), and they are at the same height as the lights. Is there any special way to waterproof them?
Dave
Reply By: japmel - Wednesday, Feb 28, 2007 at 23:02
It shouldn't matter if the connections get wet, You won't have your lights on when you do a water crossing.
And if it's dark enough to need your lights on you should not attempt a water crossing.
japmel
AnswerID: 224685
Reply By: Robnicko - Thursday, Mar 01, 2007 at 11:05
I think Narva sell waterproof connectors or you could solder the wires and then cover with heatshrink.
AnswerID: 224736
Follow Up By: Member - Matt Mu (Perth-WA) - Thursday, Mar 01, 2007 at 12:02
Was given a good hint by a trailer manufacturer to assist further...use PVC glue to coat the soldered join before you shink the heatshrink.
Havent tried it myself but that was for a boat trailer with LED lights to seal it and NEVER have to touch it again?
Might be worth trying sometime!!
Matt.
FollowupID: 485696
Follow Up By: Robnicko - Thursday, Mar 01, 2007 at 12:08
But really apart from boat trailers which spend a fair bit of time submerged under water how much water proofing do you really need................................I keep picturing the James Bond car!
FollowupID: 485700
Follow Up By: Member - Matt Mu (Perth-WA) - Friday, Mar 02, 2007 at 10:06
Nah no submarine campers here, just more for longetivity. You know with LEDs you supposedly never have to touch them again, so the only weak point would be the wiring that could corrode over time.
Might as well seal it up and never let that water in, just one task you dont have to attend to.
Matt
FollowupID: 485866
Reply By: Muzzgit [WA] - Friday, Mar 02, 2007 at 00:57
If I remember rightly, those click connectors only supply the "on/off" power to the relay, not the power that runs the lights themselves. It shouldn't need to be waterproof.
That's how my IPF900XS on GU Patrol are wired.
AnswerID: 224842
