100 series spare wheel
Submitted: Thursday, Mar 01, 2007 at 23:25
ThreadID: 42833 Views:2639 Replies:8 FollowUps:7
I have a 275/65/17 spare wheel hanging underneath the cruiser just waiting for a rock to damage it. A rear wheel carrier is not an option at this stage. Has anyone tried fitting a narrower rim and tyre as a spare so it doesnt hang down as much. If so what type rim and what size tyre. What about some type of bashplate?
Reply By: Andrew from Vivid Adventures - Friday, Mar 02, 2007 at 00:35
RWC seems easier than a bashplate. Probably cheaper too.
If you're worried that a rock would hit it adding a bashplate is not going to make that much difference ... you're still going to be dragging ya butt.
AnswerID: 224841
Reply By: pt_nomad - Friday, Mar 02, 2007 at 07:14
There seems to be some cheaper RWC's getting around at the moment for all those who have had LPG fitted. The carriers bolt over the exisitng bumper and are not the kaymar style expesive bumper replacement. You could check out a gas fitter for a supplier or price.
Paul.
AnswerID: 224848
Reply By: spliney - Friday, Mar 02, 2007 at 07:27
Local
I had the same concern and now carry a "splitty" underneath. I carry the original spare separately if the trip warrants it. Also the spare on my camper trailer is interchangeable with the LC.
Spliney
AnswerID: 224850
Reply By: Member - Ian H (NSW) - Friday, Mar 02, 2007 at 07:34
We have an 80 series and carry a 7 inch rim fitted with a 235/85 16 BFG A/T. It lies above a line from the diff to the towbar and does not get hit. However we do have a 70 mm lift and Polyairs but it still did not hit even before the polyairs. It has the same rolling circumference as the tyres you already have.
AnswerID: 224853
Reply By: Ray Bates - Friday, Mar 02, 2007 at 09:16
Have you thought about putting a false floor in the back? I did when I had mine converted to LPG. Tools and other junk go under there as well. Much cheeeeeeper than a RWC
AnswerID: 224879
Reply By: Dustin - Friday, Mar 02, 2007 at 12:53
Ring around your local Toyota dealerships and wheel sellers, the base model LC comes with split rims and are often disguared on purchase, these are a nice narrow rim and sit up well under the body. The are often on ebay too for about $10 each.
All I usually do is take the spare off and chuck it in the back when we go out for the day, up on the roof rack for longer trips. A rock damaged $280 lesson makes sure it never stays underneath when going off road.
AnswerID: 224908
Follow Up By: Andrew from Vivid Adventures - Friday, Mar 02, 2007 at 13:10
I'm not sure that the std split rims will fit the IFS ...
FollowupID: 485900
Follow Up By: Member - Davoe (Nullagine) - Friday, Mar 02, 2007 at 13:41
hes got 17 inch wheels NOT 16s
FollowupID: 485903
Follow Up By: Dustin - Friday, Mar 02, 2007 at 13:56
Oops, sorry about that, I forgot about IFS.
FollowupID: 485906
Follow Up By: spliney - Friday, Mar 02, 2007 at 16:01
In my case, mine's a 105 series, which comes standard with splits, So even though it had GXL wheels on it at purchase, I'm assuming that splits will still fit. Hence I carry a split as a spare to improve clearance. I've never actually checked! Should I??
Spliney
FollowupID: 485917
Follow Up By: Member - Davoe (Nullagine) - Friday, Mar 02, 2007 at 16:50
Splinely if you are running 265x75 tyres now your splits should still be the same rolling diameter which is the most important thing. if you have on 285s though they are a larger wheel. My 80 has a split as a spare. if you want to save more space you can bung a 79 seies 5.5 inch split and 7.5x16 tyre as the spare
FollowupID: 485926
Reply By: Off-track - Friday, Mar 02, 2007 at 23:18
If you get a 50mm+ lift it will lessen the risk of scraping the spare.
AnswerID: 224982
Follow Up By: Off-track - Saturday, Mar 03, 2007 at 02:30
By this I mean that not only does the spare become 50mm higher from the ground but the body and spare lift away from the diff so that it does not protrude like on a standard height.
FollowupID: 485961
Follow Up By: Richard Kovac - Wednesday, Mar 14, 2007 at 23:52
Are you still around?
Thanks Dick, you've helped me find a new name for w@nker...a 'Kovac'.
One day I think you may meed to apologise
Wanker
FollowupID: 488299
Reply By: Member - Alex K (NSW) - Saturday, Mar 03, 2007 at 01:13
The above comments are goood. Plus the cost of any serious bash protection is probably the cost of a new tyre. So the chances of it happening.... why bother??
AnswerID: 225006
