Hilux loud click on full left lock
Submitted: Saturday, Mar 03, 2007 at 04:58
Twinkles
My Hilux, & my daughters, both make a loud metalic click sound after being released from hard full left lock when steering. But not every time. Any one with a Hilux, IFS model, have the same? Anyone know what it is? Her car has 217,000km &
mine 48,000km.
Reply By: Member - Bucky (VIC) - Saturday, Mar 03, 2007 at 08:01
Do yourself ( s ) a favor, do not turn anything on full hard lock, go there for a split second, then back it off a little...
It may also pay to have your " limit-locks " looked at, or greased..
They just look like bolts
They are located on the inside of your front wheel hubs, on the backing plate, ( my Navara has 2, front and rear, on each ) and their job is to stop you turning the wheeels too far left or right,,
It may be as simple os smearing a dollop of grease on each and also in the slide they rub on..
If you still hear the it then have the power steering looked at
Cheers Mate
Bucky
225018
Reply By: whyallacookie - Saturday, Mar 03, 2007 at 10:48
As Bucky said, My old Rocky started doing this and a dollop of grease on the limiting bolt/pin fixed it. It was worse if on full lock and moving over a bump etc.
225051
Reply By: Member - Norm C (QLD) - Saturday, Mar 03, 2007 at 12:42
Another potential is CV joints. Check the boots to see that they are not damaged and letting grease out / dirt and
water in. Clicking on full lock is often an early indicator of CV problems.
225068
