In before the rush
Submitted: Friday, Mar 09, 2007 at 12:57
Wayne (NSW)
Just back from the local Toyota dealer to book the Troopie in for the recall.
What they will be doing is replacing the 6 bolts that hold the disk rota hub on.
I was also told that the recall came from overseas originally and Toyota was playing it safe. After the recall I wounder if Toyota will announce how many vehicles are affected.
I was also told that if there were any problems with the disk rotors or pads that they will not/ can not release the vehicle back to me in a unsafe condition.
Better check the rotors and pads before next Friday.
2 hours to do the job. That would be 4 vehicles per day for the apprentice. This is going to be a long recall to get through all the vehicles. I am glad I booked early.
If you are not the original owner of the vehicle, like me, what they will need to know is the VIN and the rego plate. This might same some time if you have that information when you go to book in. It would probably be on the letter that you should receive if you are the original owner.
Wayne
Reply By: Geoff (Newcastle, NSW) - Friday, Mar 09, 2007 at 13:08
Hi Wayne,
The cynic in me is thinking with this clause, "I was also told that if there were any problems with the disk rotors or pads that they will not/ can not release the vehicle back to me in a unsafe condition." there'll be an aweful lot of unsuspecting owners paying for their recall.
I haven't had a letter from Mr Toyota yet, I think my Troopy is a later production than the oldest date for the recall.
Geoff
| Geoff,
226337
Follow Up By: Wayne (NSW) - Friday, Mar 09, 2007 at 13:14
Geoff,
That is why I put that in the post. If the vehicle has to be worked on for the recall have the brakes checked before. It will be a lot cheaper in the long run.
Wayne
487170
Reply By: Member - Stephen M (NSW) - Friday, Mar 09, 2007 at 15:09
And I wonder how many dealers will say " sir you need some new pads they are worn right down" and there will still be 50% left on them. $100+ for them. I wonder if they'll also charge you for fitment of pads even though the calliper will be off and the pads out anyway?? Wouldn't surprise me. Good warning though Wayne for everyone. Steve M
226365
Reply By: Member - Phil G (SA) - Friday, Mar 09, 2007 at 16:45
I'll leave
mine until all the apprentices can do it in their sleep :-)))
226391
Follow Up By: Member - Steve T (NT) - Friday, Mar 09, 2007 at 16:57
Ill do them myself and if they fall of I know who to blame.
487230
Reply By: Member - Eric R (WA) - Friday, Mar 09, 2007 at 19:13
Just had my L/C done today.Booked in for 3pm all finished at 3.45pm.
No hassells,no hard sell.I haven't had any of my servicing done at any Toyota dealer for over two years.Maybe there a different breed in WA!!!!!
226420
Follow Up By: Outnabout David (SA) - Friday, Mar 09, 2007 at 22:46
For the life of me I can't see how in 45 mins. "-
you could walk into the front counter at a service department.
Sign the form to perform the work.
Have a mechanic/apprentice get your car out the car
park.
Drive to the workshop and either jack up or put it on the hoist
Loosen and remove wheel nuts
remove wheel
loosen and replace 6+ disc rotor bolts
and then put it all back together again,
get the paperwork through to the front office
once agin
sign to agree the work was done and then get ouit of there.
Either your watched stopped for a bit or they didn't do the job or it wasn't within the serial no range.
Sorry it is just the cynic in me.
487299
Follow Up By: Member - brad B (WA) - Saturday, Mar 10, 2007 at 01:28
G'day Eric
Sounds pretty good to me.
Which dealer did you use?
Brad.
487324
Follow Up By: Eric from Cape York Connections - Saturday, Mar 10, 2007 at 09:24
Outnabout If you were paying it would drag out to 4 hours work LOL.
All the best
Eric
487349
Reply By: Member - Tour Boy- Friday, Mar 09, 2007 at 19:36
I just changed my rotors and pads a couple of weeks ago and all was
well (260K) so I wouldn't panic.
I wonder if they replace the hub seal they will probably tear when they pull it apart.
Or if everyone will get
water in their bearings in the not too distant future.
Tour Boy
226426
