Under-body protection from salt
With a trip to N Straddie coming up, i thought it might be wise to give the underside of the old warhorse a spray of oil or whatever they use. Is there anywhere convenient to N Strad to do that or do 4x4 suppliers provide a service along with their accessories workshops or will I have to do it myself?
Advice muchly appreciated.
Reply By: Maddmav - Tuesday, Mar 20, 2007 at 18:11
Steve
I do a bity of beach driving locally and have used underbody paint for protection on the underside.
A good pressure spray with some CMS detergent first then after all is dry spray on the underbody paint.
I have done this every two years and no rust has appeared. Also some deterent in the doors, sills and guards in the form of fish oil or the like wont go astray either.
Vinnie
AnswerID: 228628
Reply By: Camper - Tuesday, Mar 20, 2007 at 19:10
Have discussed this topic with a few people in the business of doing this for a buck and found that one of the most effective products was ..............
"Lanotech 3000" spend a day spraying this stuff in every nook and cranny under the vehicle and you will be surprised as to how well it works.
The bad side is it cost about $90.00 for a four litre bottle, on the other hand though at least if you spend the time to do it properly you have the peice of mind that you weren't ripped off by paying Mr Bodgey to give the under body two pathetic squirts and sending you on your way minus a hell of a lot more money than $90.00 !
AnswerID: 228642
Follow Up By: Steve - Wednesday, Mar 21, 2007 at 20:25
Staun do a product at $79 per litre. The idea is to dilute it to varying degrees, depending on use. The bloke I spoke to said you dilute it at 30 to one. Doesn't seem bad value when you look at it like that. They also do 500ml for $49. So, at that rate you'd be getting15L for just under 50 bucks.
I suppose the question is, how many litres would you use to do the u/neath?
FollowupID: 489632
Reply By: Steve - Tuesday, Mar 20, 2007 at 19:44
I've been using lanotec for a while instead of WD40 and Innox. excellent product. It even gives off farmyard smells, as it is actually a wool by-product. Enough to send a Kiwi wild with desire (sorry lads)
I'll perhaps give that a go mate. Although a full day sounds a bit excessive. Still, if it does the job......
steevo
AnswerID: 228650
Follow Up By: Member - John B (QLD) - Wednesday, Mar 21, 2007 at 01:24
Hi keep innox up to it or buy alluminium
FollowupID: 489461
Follow Up By: Steve - Wednesday, Mar 21, 2007 at 10:46
actually, John, it is a Defender but surely it would still need some protection for the steel bits?
FollowupID: 489501
Reply By: F4Phantom - Tuesday, Mar 20, 2007 at 19:45
I was told the other day there is an oil spray bath that covers the whole car just near fraiser. Can anyone confirm if this is true? apparently you go in before the island and then after for a cost of around $10 a pop.
AnswerID: 228652
Follow Up By: Steve - Tuesday, Mar 20, 2007 at 20:33
N Strad
FollowupID: 489393
Follow Up By: Alloy c/t - Wednesday, Mar 21, 2007 at 09:29
Its at Rainbow beach on the road to Inskip point [ barge to Fraser ] ,, sprays oil under vehicle then on return supposedly washes oil and sand/salt off ,, if you believe that a 2 min underbody spray using high pressure semi recycled "water" gets rid of all the sand and salt go for it , you will only have wasted $10 and forced the sand and salt even further into every nook and cranny.
FollowupID: 489490
Follow Up By: Steve - Wednesday, Mar 21, 2007 at 10:45
Norht Strad not Fraser unless I change our holiday plans.
FollowupID: 489500
Follow Up By: Member - MrBitchi (QLD) - Wednesday, Mar 21, 2007 at 12:35
Alloy, when you're stuck with level 4 water restrictions, meaning no hoses at all at home, the $10 bucks is money well spent. Does a fairly good job but not as good as a pressure washer.
FollowupID: 489514
Follow Up By: Alloy c/t - Wednesday, Mar 21, 2007 at 13:39
MrBitchi ,yep I know all about the level 4 and we are soon to be on level 5 , point I was trying to make was that the Rainbow wash ON is useful , the wash OFF however does more damage than good.
FollowupID: 489536
Follow Up By: F4Phantom - Wednesday, Mar 21, 2007 at 14:56
Yeah I know its not straddie but the same idea. Also spraying oil under your car for 2 mins should give a decent coating, and as for getting it off I would have thought spraying oil again, rarther than water would be the best, or hot water with an emulsifier. In malacoota they used to have a hot high pressure gun.
FollowupID: 489559
Follow Up By: Alloy c/t - Wednesday, Mar 21, 2007 at 15:13
F4Phantom , point Im trying to make is that the HIGH pressure underbody wash using DIRTY contaminated water to clean the underside AFTER Fraser is a waste of time and $ ,,, only thing it does is force the sand and salt into every crook and cranny ,, being on level 4 , soon to be on level 5 water means no hosing at all , as for a HIGH PRESSURE hot wash ,sorry but to me that sounds like "time to replace all my seals that have/had grease " ,,, only real solution to the underbody sand/salt is a slow LOW pressure flooding with fresh water.
FollowupID: 489564
Follow Up By: F4Phantom - Wednesday, Mar 21, 2007 at 15:16
point taken, then I suggest driving into a fresh water river and sitting there for 10 minutes, then drive through at speed to get the water everywhere.
Begs the question, when you see ads and sometimes homevideo of guys driving in the surf, it looks like lots of fun, but salt is being driven at 100kph into the smallest holes, I wonder how long these cars last. I would tend to stay away from driving in salt water.
FollowupID: 489566
Follow Up By: longJohn - Thursday, Mar 22, 2007 at 13:46
The underbody sprays at Rainbow beach and noosa north shore, both do NOT spray oil anymore. They got pinged by the EPA for it.
Best thing ive heard for anti rust under body (and inside the panels too) is gear oil!
Get your old gear oil from transfer cases and gearboxes and dilute it with kero and spray it (use a garden sprayer) everywhere!
I have been told you dont use sump oil because its detergent based and will run out. Gear oil will stay put and espeicially if you drive down a dusty road first thing after you apply it.'
FollowupID: 489781
Reply By: Stu-k - Tuesday, Mar 20, 2007 at 19:50
Dont forget your permit, its something like a $250 fine for driving on the beach without one.
AnswerID: 228655
Reply By: Steve - Tuesday, Mar 20, 2007 at 19:55
$32. Got it.
AnswerID: 228656
Reply By: BUGGER ME - Wednesday, Mar 21, 2007 at 11:12
Hi steve
get yourself a copy of the latest adition of 4x4 monthly,(april) has got a great cd with this issue on fraser island, tells you and shows you the oil that they spray under vehicle, they swear by it. very good veiwing
BUGGER ME
AnswerID: 228771
Follow Up By: Steve - Wednesday, Mar 21, 2007 at 13:28
Got it yesterday. I'll give it a read
FollowupID: 489532
Follow Up By: Stu-k - Wednesday, Mar 21, 2007 at 18:02
I thought that dvd was a shocker, it was just one add rolled into another! The issue before was alot better.
FollowupID: 489604
Follow Up By: Steve - Wednesday, Mar 21, 2007 at 19:03
Agree Stu. It was one big ad-fest.
btw, I wouldn't dream of driving thru salt-water unless I had to.
FollowupID: 489618
Reply By: Mark- Saturday, Mar 24, 2007 at 12:42
Lanolin is great as a rust proofer but on the underbody sand sticks to it and wont wash off except with a steam cleaner. If this doesnt bother you, I'd highly recommend it.
I only use lanolin on internal cavities and under the floor mats - spraying a light oil/kero mix on the exposed underside with a hand sprayer works well. Sand also sticks to this but not to the same extent and is MUCH easier to wash off. Stay away from used engine oils as they contain acids and other corrosion inducing combustion byproducts.
AnswerID: 229451
Follow Up By: Steve - Monday, Mar 26, 2007 at 11:47
80% oil/20% kero????
any particular oil????
Steve
FollowupID: 490536
