Dual Battery System
Submitted: Saturday, Mar 24, 2007 at 11:01
Member - Howard P (WA)
Hi All,
Has anyone had any experience with new 'Projecta' dual battery system that is designed for charging a battery mounted in a camper trailer or caravan etc.. The kit {OBC150TK} comes with all the necessary parts for owner installation and the isolation unit is apparently mounted next to the battery in the trailer !
Thanks,
Howard.
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Mar 24, 2007 at 12:38
Howard
It is a voltage sensing relay, similar to all others.
Note that the relay must be mounted close to the starting battery and not in the trailer. If you try mount the relay in the trailer the voltage drop will cause the system to malfunction.
Derek.
229450
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Mar 24, 2007 at 12:40
Sorry I forgot to add this link to a drawing.
Trailer Charging
490218
Follow Up By: Member - Howard P (WA) - Sunday, Mar 25, 2007 at 00:58
Thanks for the info Derek, very much appreciated.
490309
