colman hot water
Submitted: Sunday, Mar 25, 2007 at 11:28
slush
ok, have one of these and would like to use it as hot
water in caravan.(I wont to hook it up when we
camp to the
water pump on the van to a tap inside,) when hooked up tho the tap and turned on the first time it works fine but when you turn the tap on again it will not relite, does anyone have a fix for this?
Reply By: Shaker - Sunday, Mar 25, 2007 at 13:26
More info needed, how have you hooked it up to the tap?
Also, are you using the Coleman accessory inlet
water pressure regulator?
You would certainly have to use the inbuilt tap on the front of the unit each time you use it, to activate the gas ignition.
229597
Follow Up By: chips59 - Sunday, Mar 25, 2007 at 15:33
no not using
water pressure reg, have it hooked up to tap. turn tap on to feed Coleman h.w.s 6lt/pm thought there may have been a way around this.
490410
Reply By: dags666 - Sunday, Mar 25, 2007 at 16:16
will not work with out the addaptor site link
http://www.coleman.com/coleman/images/pdf/2300-511.pdf same principle as an instantanious hot
water system needs
water pressure regulated with a sensor switch knows when
water is flowing through unit ,other wise it would not light without
water super heat and blow up. it a safety feature for that and and other reasons Dags
229617
Reply By: Keith_A (Qld) - Sunday, Mar 25, 2007 at 21:02
Hi Slush - I had similar thoughts - would be very convenient if it worked.
If the tap is on the inlet side, as soon as there is no
water the Coleman safety will cutoff the gas. Like all gas appliances, it then needs manual intervention - eg turn knob to off and start again. This happens in normal operation if there is air in the inlet pipe.
If there is constant (low)
water pressure from your van pump, and the tap is only on the outlet (from the Coleman), I think it should cycle - eg cut off when temp too high, then restart when temp falls - eg tap is turned on.
(The thermal cutoff is designed to work in this manner normally, and does just that.)
The fact that the outlet is unrestricted, strongly suggests the design was not intended for this style of operation however.
The risk (of damage to the unit) may be greater than the small convenience factor, so I just lug it into the van, and run it on
the bench top to heat the
water in the sink for large wash-ups (eg after roast meals etc)...........................Keith.
229690
Reply By: brett - Monday, Mar 26, 2007 at 00:38
It will shutdown if the temp gets too high and then automatically restart once it has dropped but if the
water flow stops it will shutdown and not restart. You have to turn it off and back on again if the
water flow has stopped.
Just connect your pump up to the coleman mains adapter and turn
the knob on the coleman when you want hot
water, it doesn't get much simpler than that. Assuming your pump in the van is a pressure pump that will shut off when you turn the coleman off
229719
