Rear drawers for Troopy any ideas?
Submitted: Sunday, Apr 01, 2007 at 21:06
ThreadID: 43894 Views:8517 Replies:4 FollowUps:4
Hi, I m looking to make up a false floor and a set of drawers for my Troopy. Making the floor and drawers shouldn't be too much trouble, its just getting a strong enough and long enough slider to bolt on to the side of the drawers for easy use. If anyone has any ideas, comments, plans, photos or hints on this subject it would be greatly appreciated. Are drawers the way to go anyway?
Joe
Reply By: Wayne (NSW) - Sunday, Apr 01, 2007 at 21:23
Joe,
I have made a set of draws for the Troopie. They go from the front of the back windows as I have a cargo barrier and back seat.
When I go away on the big trips I will take the back seat out and put a boxed storage area in with a lift off top. Things that I don't need every day but still want to carry will be stored in the box. On the lid of the box I will carry light bulky stuff that I will need to get too.
I will take some photos tomorrow of the runners and set up.
Wayne
AnswerID: 231095
Follow Up By: Bluey221 - Sunday, Apr 01, 2007 at 21:36
Thanks Wayne, good on ya! Thats probably a better idea having that smaller box compartment at the front so the rear drawers arn't too long and heavy. I ll check on here tommorrow for the pics.
Thanks again
Joe
FollowupID: 492006
Reply By: Member - Troopytrek - Monday, Apr 02, 2007 at 07:18
Bluey221,
We had a friend who could cad draw us a design for our draw system.
We then made them I have some photo's for you to look at. I hopefully can post some of the finished product later. Our draws only go to the back seat and have a cargo barrier that only goes to draw system height.
Once again have travelled long periods with this system and had we not put them in we would have not survived.
!MPG:6!!MPG:5!
Troopytrek
AnswerID: 231147
Follow Up By: Member - Troopytrek - Monday, Apr 02, 2007 at 07:23
By the way the photo's shown are of two different vehicles as the mate whom did the cad drawing also owned a Troopy, so as you can emagine he then got thinking he will need them two.
FollowupID: 492057
Reply By: Member - John and Val W (ACT) - Monday, Apr 02, 2007 at 09:00
Bluey,
We made something like like what you describe - a floor (bed base) at about the height of the bottom of the Troopy windows (leaves enough height underneath for the fridge), with 2 wooden (mdf) drawers underneath. Couldn't afford the width to fit in runners on the sides of the drawers, so put wheels underneath them and attached some strips of 2mm flat steel to Troopy's floor as tracks for the wheels to run on. For wheels we used big ball bearings scavenged from somewhere - about 5cm diameter and indestructable - only used 2, 1 on each side about half way along and protruding down about 5mm. Indented the tracks downwards where the wheels rest when the drawer is pushed fully in - wheel drops into indent, so drawer sits down on the tracks.
Here's a minimal picture
!MPG:4!
More pictures at
autos.groups.yahoo.com/group/troopyoz/ (see Taltech2002 in the
photos section).
There's also a big compilation of pictures on that Yahoo Troopy site in the Files area - check out the Rear Setups file.
You'll need to sign up for this site, but it's easy and is a good site for Troopy people.
Hope that helps
J and V
- Albert Einstein
AnswerID: 231166
Follow Up By: Member - John and Val W (ACT) - Monday, Apr 02, 2007 at 09:26
Ooops - when I say ball bearing, I actually mean ball race! a collection of little balls running in their housing!
J and V
- Albert Einstein
FollowupID: 492084
Reply By: Wayne (NSW) - Monday, Apr 02, 2007 at 18:30
Joe,
Here are the photos of the draw system that I have made. (I hope so anyway:-) )
The fridge is on the left with a box in front of the fridge to store tea and coffee. Under the front box is a draw with the knives and forks.
On the right bottom is the BBQ that I use when doing the tag a long trips. Above that is a draw with recovery gear and tools. Above that is another draw for food.
On the left hand side over the wheel arch is a water 60lt water tank. The axe and log splitter also sit on top of the water tank. At the back of the draws is another 60lt water tank that goes the full length of the cargo barrier. On the right is a long shelf going from cargo barrier to back door. The top of the cargo barrier there is a shelf that has the first aid kit. Under the shelf at the back of the draws is a shelf, sitting on top of the water tank, that holds the 5lt of fuel and chain saw.
Wayne
AnswerID: 231286
Follow Up By: Wayne (NSW) - Monday, Apr 02, 2007 at 18:55
Joe,
You will have to copy and paste to get the photos up.
The slide that I use is "Uni strut"
http://i178.photobucket.com/albums/w247/MakingEchoes/IMG_7154.jpg
It has a "C" section that is 22.5mm and 22x8x6mm bearing that fits inside the "C".
The uni strut is welded to a steel frame and a timber draw is made to fit.
I use 5 bearings on each side of the draw. This system has worked well for me over the past years on some very rough roads.
Wayne
FollowupID: 492183
