security cable for generator
Submitted: Monday, Apr 02, 2007 at 21:10
ThreadID: 43934 Views:6604 Replies:16 FollowUps:13
Hi i am after a cable heavy duty to secure my honda generator and solar panels. I have so far searched to no joy. The one i am looking for is a insulated cable.
If anyone knows where i can get one in brisbane and what kinda cost i am looking at it would be great.
Thanks Chris.
Reply By: Stu050 - Monday, Apr 02, 2007 at 21:24
Try a place that sells lifting gear, eg Serafini Chains or similar.
AnswerID: 231330
Reply By: Muddy doe (SA) - Monday, Apr 02, 2007 at 21:51
I ran some 1/4" chain through some clear PVC pipe. Works well.
Muddy
AnswerID: 231334
Reply By: Member - Jeff H (QLD) - Tuesday, Apr 03, 2007 at 02:37
Mate we've got 5mm cable for our panel. (and 4mm chain for the kayak)Been too proud/ashamed to use it yet: maybe if the situation arises.....................Jeff. H.I
AnswerID: 231337
Reply By: Member - Troopytrek - Tuesday, Apr 03, 2007 at 05:44
Have seen similar at a Locksmiths cheers
AnswerID: 231343
Follow Up By: Member - Beatit (QLD) - Tuesday, Apr 03, 2007 at 08:30
Haven't heard from you guys for a while, hope the 2005 journey ended well.
Kind regards
FollowupID: 492279
Reply By: Member - Andrew (QLD) - Tuesday, Apr 03, 2007 at 07:25
Try motorcycle stores....they seem to have the same problems with gear wandering :-)
Andrew
AnswerID: 231346
Reply By: Tony - Tuesday, Apr 03, 2007 at 07:30
Go to a ships chandler, and get hold of a length of SS cable 6-8mm with eyes in each end. Loop it through the items you want to secure and lock with a good padlock.
AnswerID: 231348
Follow Up By: gav99x - Tuesday, Apr 03, 2007 at 08:21
Yep that's the go, they'll even swage the ends for you for nothing (you pay for the swages obviously)
FollowupID: 492274
Follow Up By: Pajman Pete (SA) - Wednesday, Apr 04, 2007 at 07:25
Dirt cheap too, they sell that stuff by the mile.
FollowupID: 492531
Reply By: Member - Doug T (W.A) - Tuesday, Apr 03, 2007 at 07:36
Master Lock - 8127 - Bicycle Cable Lock
AnswerID: 231353
Follow Up By: Scoof - Tuesday, Apr 03, 2007 at 10:34
I used a $10.00 bike lock from Cheap as chips.
Scoof.
FollowupID: 492319
Follow Up By: Member - Doug T (W.A) - Tuesday, Apr 03, 2007 at 11:49
Scoof
A Bicycle Victoria test released in Ride On, the Bicycle Victoria members magazine, reveals that many popular types of bicycle locks can be easily and quickly broken.
Thousands of bikes are reported stolen each year from public places. Theives bust the locks and take the bikes.
'Some locks are clearly not up to it and riders need to know if a lock that looks good in the shop is going to protect their bike.' Harry Barber CEO of Bicycle Victoria said.
Bicycle Victoria tested eleven popular locks in the three categories of light cable
LMAO...POOOOOF THAT just blew you out the window
FollowupID: 492327
Follow Up By: Scoof - Tuesday, Apr 03, 2007 at 12:05
Good Morning Doug T,,
I better check to see if my genny is still there.
I thought I had got out of that one real cheap.Bugger.
Were the locks combination type or key type did it specify.
Mine is key type and looks very heavy duty about 25mm (1") in diameter around the cable.
Scoof
FollowupID: 492333
Follow Up By: Member - Doug T (W.A) - Tuesday, Apr 03, 2007 at 12:15
Scoof
Here's the wjhole story
" target="EOF" class="lbg">www.bv.com.au/bikes-and-riding/124/
FollowupID: 492334
Follow Up By: Scoof - Tuesday, Apr 03, 2007 at 13:03
Thanks Doug ,
D lock wouldn't suit my application , but it gets you thinking.
If the lock was too good the buggers would probably wreck the whole bloody thing (bike, generator)bashing the crap out of it trying to break the lock.
Cheers Scoof
FollowupID: 492345
Follow Up By: Member - Doug T (W.A) - Tuesday, Apr 03, 2007 at 13:11
Scoof
No your wrong mate, If they can't steal it then they wreck it coz if they can't have it niether are you even though it's yours
FollowupID: 492347
Follow Up By: Scoof - Tuesday, Apr 03, 2007 at 15:02
Yep your right again,
I would like to catch the mungels.
We are currently fixing a hole cut in the fence at work were the assholes got in last week and stole the 2 way radio out of the crane.Only noticed the hole today right under a tree so it was very hard to see.
I would love to cave their knees in so they couldn't jump any more fences.
But probably get my own head smacked in.
Cheers Scoof
FollowupID: 492361
Reply By: Member - michael H (NSW) - Tuesday, Apr 03, 2007 at 08:43
I have a 64 watt unisolar panel that has an aluminium frame it has a lead of about 7.0m long so I swaged eyes on each end one bigger than the other.
But before you put the last one on I drilled 8 x 6mm holes near each corner & slightly elongate the hole & threaded the 4mm cable through the panel & swage a loop to the end with the cable the same length as your wire & padlock it near your battery.
You could do the same with your gennie make up a length of cable the same as your extension lead & leccie tie or tape them together.
Cheers Michael
AnswerID: 231361
Reply By: DIO - Tuesday, Apr 03, 2007 at 09:00
You can get them at Hardware Stores, Bike Shops, Auto Accessory/Parts Stores, $2 Shops - in fact almost everywhere. Shouldn't have to pay more than $10 - $15 for good length cable and lock.
AnswerID: 231367
Reply By: MEMBER - Darian (SA) - Tuesday, Apr 03, 2007 at 09:32
The Python brand cable locks, from Hardware stores etc seem quite robust - thick cable and a sturdy, endless locking system - the thicker the cable model chosen, the better. Re multi strand steel cables - they are hard to cut with conventional bolt type cutters (might be impossible - they just squash flat) - thieves need a parrot beak cutter (bypass cutter - like scissors) - available but not always "laying around". As mentioned the ships chandlers can swage cable lengths for you at reasonable cost (they use this stuff for mast stays etc). While the cable is difficult to cut, the weak point of that setup re security (in my view) is the swage itself, which could easily be cut with bolt cutters - then you don't need to cut the cable !
I use a mixture of chains and swaged cables, and keep the digits crossed !
AnswerID: 231377
Reply By: j100 - Tuesday, Apr 03, 2007 at 09:45
Crykies
Honda sell a security cable
"Kryptonite Braided Steel Cable" part # L2108-18
Contact your friendly honda dealer
PS I'm not associated with them
Jaap
AnswerID: 231379
Follow Up By: Max - Sydney - Tuesday, Apr 03, 2007 at 17:47
Kryptonite would be no good - I go weak when i get near it!
Supermax
FollowupID: 492404
Reply By: Shaker - Tuesday, Apr 03, 2007 at 11:48
Cables are much better than chains, but the padlock is the weak link & easy to remove with a 3' masterkey (boltcutters).
Insurance companies won't cover boats & trailers using chain & padlock.
Some cables have inbuilt locking that may be more secure.
AnswerID: 231411
Follow Up By: Turist (The Original One) - Tuesday, Apr 03, 2007 at 12:21
A battery operated Dremel tool with a thin cut off disc will go through the lock, chain or cable in about 30 seconds.
Handy gadget, recharge lasts a long time and fits in your pocket.
Very popular around Lakemba/Bankstown area in Sydney.
Probably fit under a Burkha as well.
FollowupID: 492336
Reply By: Alloy c/t - Tuesday, Apr 03, 2007 at 13:13
Any lock / cable / chain will only stop honest people and the oportunist thief , that said any one who steals from a campsite must "need" the item more than the owner , and no amount of "security" will stop them , as an aside ,the brotherinlaw used to padlock the zipps on his c/trailer windows and doors until it was pointed out to him that any and all canvas opens to a knife and its easier to replace an item or 3 than replace the slashed canvas.
AnswerID: 231423
Reply By: KiwiAngler - Tuesday, Apr 03, 2007 at 14:13
I have had these for about 5 years now, as I travel mostly on my own and often leave my campsite with gear setup (solar etc) and reckon they do the job very well. They have te added bonus that if they are cut or he circuit is opened they make one hell of a noise.
LockAlarm website
AnswerID: 231432
Follow Up By: Scoof - Tuesday, Apr 03, 2007 at 15:17
What a fantastic idea.
It would certainly draw some attention.
Scoof
FollowupID: 492363
Reply By: crykies - Tuesday, Apr 03, 2007 at 20:49
Hi all.
Thanks for the replies on this topic. Today i looked in the yellow pages and found a cable place that made me up a 8m stainless steel cable with eyelits at both ends for $20. I know if they want the item they are going to take it one way or another but least they just can't walk up and walk away without using bolt cutters etc.
What i got was 10mm SS wire cable covered with pvc.
Many thanks Chris.
AnswerID: 231513
Reply By: ross - Tuesday, Apr 03, 2007 at 23:53
Bunnings has half a dozen types and sizes from $9 -$60 . The also have plastic coated chain to which you can add your own lock.
I was down there today buying my security requirements for Alice Springs.
I have locked everything on its own separate cable with keyed alike padlocks rather than one long cable.
So they ll have to chew through 4-5 cables if they want everything
AnswerID: 231563
