GPS Trackfiles/Waypoints on EO
Submitted: Tuesday, Apr 10, 2007 at 09:38
ThreadID: 44150 Views:3519 Replies:4 FollowUps:12
Is there anywhere on ExplorOz where i can upload some trackfiles and/or waypoints for all (or only members) to access?
I have some high quality trackfiles from my local 4wd area eg Cape Palmerston which several members have asked for, so was thinking of making it freely accessible here instead of off-site. Is there somewhere easily searchable for all to access such files?
Maybe David et al could allow uploading of these files into a new subsection under the relevant place area eg Site Link to keep all information in the one spot.
Andrew
Reply By: Trevor R (QLD) - Tuesday, Apr 10, 2007 at 09:59
Hi Andrew,
Your idea to keep it all together is good, but for now I can only suggest putting the file here
Hope this helps.
Trevor.
AnswerID: 232517
Follow Up By: Member - Andrew (QLD) - Tuesday, Apr 10, 2007 at 10:16
Thanks Trevor,
I was hoping i had missed another obvious area ;-)
Andrew
FollowupID: 493401
Reply By: Member - Doug T (W.A) - Tuesday, Apr 10, 2007 at 10:07
Andrew
I only found out about this the other day, see up the top of the page is Home/Forum/Trader...........to.........Members, just put your cursor on that and look File Swap
Doug
AnswerID: 232519
Follow Up By: Member - Andrew (QLD) - Tuesday, Apr 10, 2007 at 10:15
Thanks Doug,
I saw that area (with your file in it) however thought that it may be too messy to manage and find....I would rather see something more structured/searchable easily by all (the fileswap area is only as good as the filename that members choose eg, if i'm looking for Cape Palmerston, a file called windmill_bay may not be obvious to visitors that it is useful.
Andrew
FollowupID: 493399
Reply By: Member - Doug T (W.A) - Tuesday, Apr 10, 2007 at 10:20
OK then if you have your own home page put them up there , as like mine
members.westnet.com.au/dtilley/gps.htm
AnswerID: 232522
Reply By: Bonz (Vic) - Tuesday, Apr 10, 2007 at 17:19
Member File Swap is what you are talking about, and its available now, just hover your pointing device (or mouse) over Members in the manu above and click on Member FileSwap.
AnswerID: 232573
Follow Up By: Member - Andrew (QLD) - Tuesday, Apr 10, 2007 at 17:35
Trevor and Doug had already suggested this option earlier, however i am after another (better?) option.......the fileswap area is just a mixture of files and, as explained before, can be useless if not named correctly. Even a subsection, like Checklists and Planners, Cooking and Recipes, distinguish the type of information better than throwing it into one large miscellaneous section. Maybe a subsection called Waypoints/Tracklogs etc could be adequate.
Andrew
FollowupID: 493473
Follow Up By: Bonz (Vic) - Tuesday, Apr 10, 2007 at 17:37
Thats a good idea, I might suggest that to the site admin if that is OK with you?
FollowupID: 493474
Follow Up By: Member - Andrew (QLD) - Tuesday, Apr 10, 2007 at 17:47
That's fine with me :-) Would suffice if there are no other options.
Andrew
FollowupID: 493476
Follow Up By: Bonz (Vic) - Tuesday, Apr 10, 2007 at 17:49
Done! Lets see what the HTML guru says
FollowupID: 493477
Follow Up By: Bonz (Vic) - Monday, Apr 16, 2007 at 20:02
Well I didnt look there before but theres Checklists and planners and Cooking and recipes in there and if you see a need for others then let David know and he may slot them in there
FollowupID: 494754
Follow Up By: Member - Andrew (QLD) - Monday, Apr 16, 2007 at 20:13
I thought that's what you were doing....asking them to set up another subsection?
Andrew
FollowupID: 494759
Follow Up By: Bonz (Vic) - Monday, Apr 16, 2007 at 20:15
Ja I did and was advised that if we suggested some other David could insert them
FollowupID: 494760
Follow Up By: Gramps (NSW) - Monday, Apr 16, 2007 at 21:56
"and was advised that if we suggested some other David could insert them"
LOL please explain or at least interpret hahahahahaha
FollowupID: 494788
Follow Up By: Bonz (Vic) - Monday, Apr 16, 2007 at 22:14
Well we already have: (In Member Fileswap)
Conversion and Calculation tools
Cooking and recipes
Radios and Communication
Safety and Survival
And its been suggested we add
Waypoints/Tracklogs
Any others to suggest?
FollowupID: 494799
Follow Up By: Gramps (NSW) - Monday, Apr 16, 2007 at 22:22
Yep, that's what I thought you meant :)))))))))))))
FollowupID: 494803
