Winch vandal's
Submitted: Tuesday, Apr 10, 2007 at 19:37
Member - Daryl C (VIC)
Heard a lot of horror stories after biting the bullet & buying a Warn 9000 winch.
Apparently some 1/2 wit can easlely earth the winch after connecting it to your tow ball or someone else's veh & create havoc, my Q. is does any one now of a easy or cost effective way of isolating your winch or veh (preferably with out having to reset your am/fm each time you go to a public car
park)?
Cheers Daryl.
Reply By: Member - Blue (VIC) - Tuesday, Apr 10, 2007 at 19:40
A lot of stories but to my knowledge, no photographic evidence to date. I have seen one photo billed as evidence but someone laid claim to it and told a completely different story as to how the damage occured...
232621
Follow Up By: Member - Blue (VIC) - Tuesday, Apr 10, 2007 at 19:44
Also, a manual isolator under bonnet would sort out most of your fears...
493505
Follow Up By: navaraman - Wednesday, Apr 11, 2007 at 17:03
My winch is rated at upto 480A, I haven't seen an isolator with that rating anywhere although they may be available..
493646
Reply By: Robin - Tuesday, Apr 10, 2007 at 19:41
I just mounted my controller up close to battery under bonnet - keeps drier to
Robin Miller
232622
Reply By: hoyks - Tuesday, Apr 10, 2007 at 19:42
There was some discussion on isolators here:
Site Link
232624
Reply By: GQ_TUFF - Tuesday, Apr 10, 2007 at 20:15
Same here....a manual isolator under the bonnet, nothing happens with out this engaged
Cheers Stefan
232635
Reply By: Member - Ian H (NSW) - Tuesday, Apr 10, 2007 at 20:37
Oh yes it can. Just pull out the winch clutch, pull out some cable and hook it to something that does not move like a power pole. Would not be seen at night and gives the driver a real jerk when the cable slack takes up.
232644
Follow Up By: V8Diesel - Wednesday, Apr 11, 2007 at 09:31
Good point.
Use a padlock.
493567
Reply By: Member - Doug T (W.A) - Tuesday, Apr 10, 2007 at 20:41
Simple really, think to your self how often it is used , and you will then probably use the same type of manual isolator as I do, don't hook it to the battery terminals until it's needed , When I got stuck in the SD
Easter 06 it took very little time to connect the cables to the battery ,
232648
Follow Up By: Member - lyndon K (SA) - Wednesday, Apr 11, 2007 at 07:39
Good idea, think i will do that myself, just have it hooked up when i go bush.
493552
Reply By: handy - Wednesday, Apr 11, 2007 at 07:22
dont worry to much if you have the 5 pin plug. it can only be done if you have the 3 pin plug. cheers
232677
Reply By: Middle Jeff - Wednesday, Apr 11, 2007 at 08:13
Hi Daryl
Just put a small relay on the small earth wire and have it set up on ignition so it only works when the key is on, quick, cheap and simple.
Have fun
Craig
232684
Follow Up By: Waynepd (NSW) - Wednesday, Apr 11, 2007 at 13:37
The relay works
well and you always have access to your winch when you need it.
493610
Reply By: V8Diesel - Wednesday, Apr 11, 2007 at 14:13
Any pics out there?
232727
Reply By: Member - Davoe (Nullagine) - Wednesday, Apr 11, 2007 at 14:27
just sit your duel battery isolator to off
232729
Follow Up By: navaraman - Wednesday, Apr 11, 2007 at 16:57
unless your winch is hooked up to the start battery.
493644
Follow Up By: Member - Davoe (Nullagine) - Friday, Apr 13, 2007 at 15:13
wouldnt make a difference
494013
Reply By: Truckster (Vic) - Wednesday, Apr 11, 2007 at 15:51
Wow, this is ancient... havent heard this story for 2-3 yrs!
232754
Reply By: Tim - Wednesday, Apr 11, 2007 at 16:09
I could be wrong but when I've been playing around with mone, I thought it was a double pole switch which means its not as simple as a paper clip.
Tim
232757
Follow Up By: Member - Andrew (QLD) - Wednesday, Apr 11, 2007 at 16:54
two paperclips maybe? :-)
Andrew
493642
Reply By: Member - Daryl C (VIC) - Friday, Apr 13, 2007 at 12:06
Thanks every one for taking the time to reply. I have disconected the main power lead - 10sec - & will reconect when needed.
233126
