Troopy on The Ghan
Submitted: Thursday, Apr 12, 2007 at 17:07
GrahamK
Does anyone have any experience temporarily lowering the
suspension on a 75 series troopy to fit on the Ghan railway cars which have a height limit of 2 metres but the vehicle is 2.1 metres high. Some ideas are to put smaller
wheels and tyres on the rear, or somehow compressing
the springs with a ratchet strap. letting the tyres down to 15psi only drops it 25 mm
Reply By: Hairy - Thursday, Apr 12, 2007 at 18:21
Gday,
Short answer..No..But
Where are you trying to send it and from where?
232993
Follow Up By: Hairy - Thursday, Apr 12, 2007 at 19:19
Ring around the truck companies in
Darwin, you might get it on as a back load.
It will be dearer but a lot less hassel.
493871
Follow Up By: Dion - Friday, Apr 13, 2007 at 08:35
Darwin to
Port Augusta via
Adelaide.
The only railways that will load/unload cars onto rail trucks at
Port Augusta is Pichi Richi Railway which only runs between
Quorn and
Port Augusta.
GSR are not interested in loading/unloading at
Port Augusta, so much so, you actually can't do it from their trains now anyway.
Dion.
493930
Reply By: Willem - Thursday, Apr 12, 2007 at 19:00
Yeah...Hilux rims and 205's
233000
Follow Up By: GrahamK - Thursday, Apr 12, 2007 at 19:21
can you measure the distance from the centre of the hub to the outer tread of the tyre please?
493872
Follow Up By: GrahamK - Thursday, Apr 12, 2007 at 19:23
yes I thought of that also but at $99
Darwin to
Adelaide that price would be hard to beat
493874
Follow Up By: KiwiAngler - Thursday, Apr 12, 2007 at 19:37
u also have to remove all roofracks and 'other' protruding 'bits'
493882
Follow Up By: D-Jack - Friday, Apr 13, 2007 at 21:40
Imagine the gear ratios in 1st low with those size
wheels and tyres!
494088
Reply By: V8Diesel - Friday, Apr 13, 2007 at 21:41
Used to just chain axles up on trucks. Might work.
233225
Reply By: disco driver - Friday, Apr 13, 2007 at 21:55
Hi Graham,
I trust that you are aware that the $99 rate for your vehicle only applies when you are a passenger on the same train.
It might be possible to have your truck loaded onto a flat bed similar to those used on the freight
services, they have semi's with containers chained onto them and they are
well over 8 Ft high. Might be worth chasing up
Disco
233231
Follow Up By: Dion - Friday, Apr 13, 2007 at 23:14
Semi's with containers haven't been carted in thism manner for donkeys years. The only road vehicles currently transported on the CAR as freight are NTF (SHELL) tankers which are not chained down. They are loaded onto flat trucks which have shallow sides on them to contain the
wheels of semi trailers, with the king pin on the skid plate held by a pneumatically raised
turntable. Quick and easy.
The answer Disco Dave gave may have been applicable 25-30 years ago, but hasn't been practised since then.
Dion.
494116
Follow Up By: Dion - Friday, Apr 13, 2007 at 23:16
Also GSR psgr
services don't run single level trucks, because they are uneconomical, if it don't fit on a bi-level car carrier truck, it won't go on a psgr service.
Dion.
494117
Reply By: GrahamK - Saturday, Apr 14, 2007 at 13:22
Have tried cranking down the
suspension but unable to get the roof height on the troopy below 2.0 metres so it looks like I will have to find a road haul company to take the troopy to
Adelaide whilst we enjoy a couple of days in luxury on the Ghan.
Does anyone have a contact with a trucking company
Darwin to
Adelaide?
Graham
233327
