Pajero Np clutch problem
Submitted: Sunday, Apr 15, 2007 at 08:45
ThreadID: 44323 Views:5934 Replies:6 FollowUps:8
I have just received an advice from Mitsubishi Motors stating"the positioning of the a/c drain of your vehicle may allow moisture to enter the clutch housing where evaporation can result in corrosion causing hard operation of the clutch pedal & difficult shifting of the gears just after starting thge engine.In the worse case, the clutch may be prevented from disengaging".
My pajero is a 3.2DID & I would appreciate any comments from other pajero owners on this subject.
It would appera that there is no drain hose fitted as the advice says that the dealer will fita a/c drain hose to your vehicle.
Reply By: Member - Andrew (QLD) - Sunday, Apr 15, 2007 at 10:44
IS this an official notification ie. letter or just your local dealership mentioning the fact? I take it MM means a letter similar to a recall notice?
My warantee is due to expire in the next 3 months, so would like to make sure that any issues don't become my responsibility :-)
BTW, i don't see any problems with A/C drainage going over my clutch area, especially when i run the A/C continuously up here in North Qld.
Andrew
AnswerID: 233510
Follow Up By: Member - Vince B (NSW) - Sunday, Apr 15, 2007 at 12:12
Hi Andrew.
The letter is an official notification from Mitsubishi Motors Australia, Clovelly SA.
I don"t know how long the problem has existed, maybe the dealers fixed any problems when vehicles were serviced.
Vince.
FollowupID: 494385
Follow Up By: donks1 - Sunday, Apr 15, 2007 at 14:04
we had 3 sold to bowen council and wwere the first dealer to report it to mitsu..
as i said below, a/c is used and then car left over the weekend..
monday morning the clutch would shudder for the first few km's
donks
FollowupID: 494396
Reply By: donks1 - Sunday, Apr 15, 2007 at 13:24
this is an old issue
mainly causes problems when car has been used with a/c and then left for a few days...
we struck this with late nm's and early np's as council cars that are left at the depot over the weekend
i don't know why you would get a letter now
there was no recall on them ..... just an inspect at service bulletin..
donks
AnswerID: 233528
Follow Up By: Member - Vince B (NSW) - Sunday, Apr 15, 2007 at 13:28
Irecently advised M/M of change of ownership. Apparently first owner did not have drain hose fitted.
Vince
FollowupID: 494391
Reply By: cityslicker - Sunday, Apr 15, 2007 at 13:33
I've got the notice. Mine is an NP manual diesel and goes in next Monday. I'm going to try to find out a bit more about the problem next week.
AnswerID: 233530
Follow Up By: donks1 - Sunday, Apr 15, 2007 at 14:00
all it is is that the drain hose from the a/c is too short and the water drips into the bellhousing. if the car is left to stand for a period of time, it creates a rust spot on the flywheel and the pressure plate. the fix is simply a longer hose running down the bell housing....... a piece of garden hose will do it
FollowupID: 494395
Follow Up By: cityslicker - Sunday, Apr 15, 2007 at 18:46
OK Thanks Donks
FollowupID: 494441
Reply By: donks1 - Sunday, Apr 15, 2007 at 14:01
for got to add that it just causes a slight shudder until the rust spot is cleared
donks
AnswerID: 233534
Reply By: pickle - Sunday, Apr 15, 2007 at 15:48
Donks is spot on with it being from the Air Con. It was reported in our forum ( forum.pajeroclub.com.au/forum/default.asp ) quite a while ago. Obviously the previous owner did not get notified . Normally they would put a sticker on vehicle near the tyre placard if the recall has been done.
Dave
AnswerID: 233551
Follow Up By: Member - Vince B (NSW) - Sunday, Apr 15, 2007 at 16:08
Thanks Donk1 & Pickle.
I will book in with our frieldly local M/M tomorrow.
Vince
FollowupID: 494411
Reply By: Member - Andrew (QLD) - Monday, Apr 16, 2007 at 16:44
I received my letter today after getting my 120,000 service YESTERDAY....you would thought that someone with a Mitsubishi dealership, where i have received regular services since new, would have the knowledge to do it at the same time!
Andrew
AnswerID: 233810
Follow Up By: Member - Vince B (NSW) - Monday, Apr 16, 2007 at 18:22
Hi Andrew.
If this an old problem it makes you wonder why it wasn"t fixed at previous services!!!!
Have you had any clutch problems?
Vince
FollowupID: 494718
Follow Up By: Member - Andrew (QLD) - Monday, Apr 16, 2007 at 18:36
No clutch problems so far....touch wood, though i use the vehicle almost every day which could be the difference.
Andrew
FollowupID: 494723
