long range tank
Submitted: Monday, Apr 16, 2007 at 12:58
whackywombat
Just can't decide which way to go? I've got a 2006 Dual cab 4x4 diesel hilux and I want to fit a long range
fuel tank . The choice is between replace existing
tank with a long
ranger (140lt) or fit a (70lt) auxiliary
tank made by opposite lock. Has anyone changed there
fuel tank? Any help would be great.
Thanks heaps
Reply By: barney rubble - Monday, Apr 16, 2007 at 13:22
Gday wombat mate i had a aux
tank fitted to the gq and while the range was great we ussually annoyed several people filling the mongrel b-----d fill i think they call it also found the transfer pump didnt work as
well on the corrugations
i would go one
tank if ya can fit it without comprimising ground clearance Cheers
233773
Reply By: whackywombat - Monday, Apr 16, 2007 at 13:36
Hi Barney
The auxiliary
tank fits above the spare wheel and gravity flows into the main
tank. Also fills from the same inlet as existing main
tank. But will check out ground clearance on long
ranger tank
233781
Reply By: marq - Monday, Apr 16, 2007 at 14:34
I would also consider a Long Range Automotive
tank
Site Link
233789
Reply By: Vince NSW - Monday, Apr 16, 2007 at 16:42
Hi Wombat,
I have fitted a "long ranger" Axe
tank (80lt). Would I do it the same way again ?
1. It is a pain to fill as it uses the same filler as the main tankl so you can not choose where the
fuel goes.
2. Transfer pump is very slow, takes about 30 mins to do the whole 80 lt.
On the plus side, the aux
tank fits up very high & has never been a prob with clearance
Vince
233809
Follow Up By: Member Carree (WA) - Monday, Apr 16, 2007 at 22:34
Hi Wombat
I recently fitted a extra
tank to my brothers new Navara, under his tray. If you have a traytop let me know and I will give more details. Best of luck.
494810
Follow Up By: whackywombat - Tuesday, Apr 17, 2007 at 07:40
Not a tray back, its the factory tub
494840
Reply By: Stu-k - Monday, Apr 16, 2007 at 22:45
If its a SR5 you will lose your trip computer with one
tank also
233906
Follow Up By: whackywombat - Tuesday, Apr 17, 2007 at 07:44
I was under the impression by replace the main they used all original gear from inside the factory
tank. Will trip computer still work but not be accurate?
494842
Follow Up By: Stu-k - Tuesday, Apr 17, 2007 at 19:27
Yep
494937
