5th gear cluster Ford Courier/Mazda Bravo
Submitted: Monday, Apr 16, 2007 at 20:19
ThreadID: 44386 Views:5971 Replies:3 FollowUps:0
Mate has done 5 th gear in his Ford / Mazda Bravo / Courier
2000 model with the 2.5 TDI
Can anyone out there help us,,,5th gear cluster and a full bearing kit ,,
How much ?,, and where do you get it ???
The Box is out on the ground, Not too sure,, either a Reco Box or or the bits,,
Thanks all
Bucky
Reply By: 751daimlers - Monday, Apr 16, 2007 at 20:45
Hi Everyone.
Thanks for setting this up bucky.
Please forward all replies to John at scandj@bigpond.com
have a great day.
AnswerID: 233871
Reply By: Trevor R (QLD) - Monday, Apr 16, 2007 at 21:26
I wonder if there is one components manufacturer supplying many vehicle manufacturers. I know of plenty of Nissan's from this build time having 5th gear drama's (usually spline shafts) and many Cruisers from 99 with bearing and 5th gear hassles also. Coincidence????
Sometimes better to rebuild what you know. SO long as you know full history it can be safer. If you intend on keeping the vehicle that is otherwise just the cheapest option will do.
Regards, Trevor.
AnswerID: 233888
Reply By: hiab - Tuesday, Apr 17, 2007 at 18:09
we did one in the workshop about 3 weeks ago, the owner went for a reco box, when it arrived same problem, sent it back, ordered another, it got sent to perth instead of katherine, many phone calls later we found that the truck had passed through katherine and the box was in darwin.... if you are handy with the spanners you might do it yourself as 5th is outside the box and not too hard to get at.
AnswerID: 234014
