RD28 Remove cylinder head
Submitted: Tuesday, Apr 17, 2007 at 14:23
Stevepick
I suspect a blown head gasket in the Nissan Laurel 92 RD28 Diesel
Its pressurising the cooling system and eventually runs out of water/overheating. I have been know to drive it prety hard at times. Car done has 200K and will need new cam belt
My Question is: How hard is it to remove and replace the head gasket. I don't want to spend the $ at the garage if I can help it!
Reply By: Member - Kiwi Kia - Tuesday, Apr 17, 2007 at 15:59
I think you need to ask yourself why the gasket may have failed. You will not know till you have taken it off but you may need to give the head a skim as it may have warped. I would definitly do it anyway. My point is you may need to do a little more then just swap out the head gasket.
233985
Reply By: On Patrol (Aust.) - Tuesday, Apr 17, 2007 at 16:28
Stevepick
Talk to GQ_TUFF, he's just been through the mill re this very subject and it turned out not to be the head gasket after all!!!!
All the so called "Experts" said yeah mate deffinatley Head Gasket Mate.
He replaced the pump and reassembling it all he had the thermostat housing "snap". When he got the new housing and re assembled it all, problem gone.
233993
Follow Up By: On Patrol (Aust.) - Tuesday, Apr 17, 2007 at 19:09
GQ_TUFF has become a new member today. He is now known as stefan P.
Just to P1ss me off.
494935
Reply By: donks1 - Tuesday, Apr 17, 2007 at 17:55
hi steve
if you are planning on doing this yourself, you will be saving a good $600 + in labour, but don't do half a job..
do you know what you are looking for as far as "blown gasket" goes? ( i mean once you have it off )
get it crack tested and at least machined.
if crack test and inspection of gasket shows no
sign of the cause, look further.
i know you don't want to spend big bucks but a few extra dollars is
well worth it if you don't have to do the job twice...
if you know what you are doing as far as timing belt goes, you should have no real troubles with the rest of the job
what is the oil like..... milky on the dipstick or under the filler cap???
is there oil in the
water???
rd 28's are generally pretty reliable
its the bolt on bits that cause most issues
good luck
donks
234009
Follow Up By: Stevepick - Tuesday, Apr 17, 2007 at 19:45
No obvious oil in the
water at all - I need to find out if there is exhust gas in the
water...Do you know how this is done?
494942
Follow Up By: donks1 - Tuesday, Apr 17, 2007 at 20:28
you can get a head check done
any reasonable mechanic will have this test available
basicly it involves putting chemicals in a " tube" which is held on the radiator where the cap goes. depending on the colour the chemical changes will tell you if there is exhaust gas in the
water..( sorry for being a bit vague... 1/2 bottle of jack does that)..
where are you .. i might be able to point you in the right direction for mechanical advise???
its a simple check.
donks
494959
Follow Up By: donks1 - Tuesday, Apr 17, 2007 at 20:31
you mention the cressida.. is that a mx83 or earlier
if its a mx83 ( twin cam ) you should have no troubles with the rd28
donks
494961
Reply By: Stevepick - Tuesday, Apr 17, 2007 at 19:37
Thanks for the reply's so far... So far I've blown a couple of the small hoses behind the injector pump. There are reasonably large bubbles (and quite a lot of pressure when I remove the
water cap.
I think I need to find out if there are exhaust gasses in the cooling system... does any one know how I would do this?
The engine got HOT about a year ago (it blew a hose while my wife was driving)
From that point on there has been a small discharge of oil from no1 injector right where enters the head (today I put soapy
water around while it idling which identified a slight compression leakage at this point)
I replaced the head gasket on my GLX2.8 Creseda about 5 yrs ago (an found out it wasn't the head gasket when I finished) so I should be able to do the job if I have too. Steve (Stanmore Bay WPG)
234037
