Tyre pressure on Goodyear Wrangler MT/R
Submitted: Friday, Apr 18, 2003 at 01:00
David
What tyre pressure should I run on this tyre for highway driving ?
Size is 32x11.5R15
Thank you
Reply By: GaryInOz (Vic) - Friday, Apr 18, 2003 at 01:20
What sort of vehicle? depends a lot on the weight of the vehicle.
17871
Follow Up By: IAMGQ - Friday, Apr 18, 2003 at 01:26
Diesel GQ LWB........
only light load.......
camping equipement..........2 adult........
11210
Reply By: Member - Tony and Helen - Friday, Apr 18, 2003 at 08:37
David try 38 - 42 front and 32 36 rear
have a great
easter
tonyshe said you not going down there with me in here.
17880
Follow Up By: Allyn (Pilbara) - Friday, Apr 18, 2003 at 12:23
Tony,
Why greater pressure in front tyres?
I think this is incorrect.
David I have same tyres on my 80 series and run 38-40 on rear and 34-36 on front. I do a lot of highway
miles with reasonable loads so I may not be the best guide for your situation.
11220
Follow Up By: Member - Tony and Helen - Sunday, Apr 20, 2003 at 10:40
Allyn
I am quoting pressures on my troopy, with a light load as stated above.
Higher pressures on front because the load is higher (engine) weight of load increases more on the rear and if i was crring a heavy load i run 38 - 40 rear on the h way.
This does increase the harshness of the ride but it also increases the safety and the road handling should you get out of shape.
Hope you have/had a good
easter
she said! your not going
down there with
me in here.
11256
Reply By: Rob from Cairns Offroad Training & Tours - Friday, Apr 18, 2003 at 10:12
David I run the same tires and size on my 80 series and run them at 32-34 and 26 -28 offroad. They have a very stong sidewall and the ride is very harsh if run at much more than 34 On a smaller lighter car like yours 32 should be fine provided it steers ok. Cheers RobCairns Offroad Training & Tours
17888
Reply By: Member - Cocka - Friday, Apr 18, 2003 at 10:35
Refer to post 3911
I was talking about the same tyre then and Rob posted a simila reply. I have tried the lower pressures and am satisfied also think they are a little better in the wet.
Carpe Diem
17890
Reply By: Eric from Cape York Connections - Friday, Apr 18, 2003 at 11:28
David I have the same size tyres on a 60 . On road i run fully loaded 2 adults & 2 kids rear 39 front 36 .
Off road same load I run front down as low as 21 psi and rear down to 28 psi and to date not had a problem . the tyres have done 35000 k and still have 50% trread left.
All the best
EricCape
York Connections
17891
Reply By: Member - Stephen- Friday, Apr 18, 2003 at 19:46
david,i run
mine at 34psiand the ride is pretty good .tried them at 36psi and the ride starts to get a bit harsh.i rotate them every 10000k and they seem to be wearing ok.they have 30000k on them and are just over half worn.my 4wd is similar to yours ,except
mine is petrol.
regards stephenjNQ
17905
