Steel jerry cans
Submitted: Thursday, Apr 19, 2007 at 10:05
ThreadID: 44490 Views:2126 Replies:5 FollowUps:1
I've been given 2 steel jerry cans, in real good condition on the outside. One even has super petrol still so the seals are good. Unfortunately when I flushed them with petrol some gunk came out. Not much but it worries me. Is there some way of cleeaning them out effectively? I want to use them for diesel and when I transfer from jerry can to vehicle I always use a funnel with a fine filter mesh.
Thanks, Geoff
Reply By: Robin - Thursday, Apr 19, 2007 at 10:21
Hi Geoff
I wouldn't bother as 1% petrol in diesel isn't an issue - and you are using filter for particles anyway
Robin Miller
AnswerID: 234428
Reply By: Tony - Thursday, Apr 19, 2007 at 10:27
Re-flush them with a bit of petrol until you get no more gunk out. Anything left will get picked up in the funnel.
AnswerID: 234430
Follow Up By: Vince NSW - Thursday, Apr 19, 2007 at 10:51
I have used a handfull of small stones & some petrol. Give a good shake, but watch out when you open the can as you will build up a small amount of pressure.
Vince
FollowupID: 495375
Reply By: Member - Duncs - Thursday, Apr 19, 2007 at 12:23
I always use a piece of material from the wifes old panty hose, as a final filter.
I use a syphon and simply hold a few layers of the material over the end of the hose with a rubber band or some gaffa tape. I have also used the same system over the end of a funel. With or without the mesh filter in the funnel I usually get something in the pantyhose.
Remember to replace the rubber band/gaffa tape every time you transfer fuel because I don't reckon either will stand up to the fuel very well. Even if they would I won't take the risk.
Also if you leave a little bit of fuel in the bottom of the jerries and keep them properly closed all the time you will get less problems with corrosion on the inside.
Duncs
AnswerID: 234451
Reply By: phil - Thursday, Apr 19, 2007 at 19:46
How old are the jerry cans?
I am still using 3 of them which are marked W^D 1952 I guess this makes them 55 years old. Nearly as old as I am!
There are bits of red paint flakes occasionally, but nothing which is a problem if a simple filter funnel is used.
I just filled them all as I got a 20 cent/l fuel discount from a wine offer.
Phil I
AnswerID: 234570
Reply By: obee - Thursday, Apr 19, 2007 at 21:29
the mesh is there to stop water more than anything else. A bit of grit will stop in the car's filter but water will block it total
AnswerID: 234603
