rear BRAKE service
Submitted: Sunday, Apr 22, 2007 at 14:22
steve21
Hi All.
just had rear brakes replaced on my LC 80 1995. new pads n discs. 1st use today and travel over 40-45km/h am getting a huge shudder through car, and seems like car swaying, got home and drivers rear disc real hot and burning smell, other side feels ok, am gld wasn't going awy this weekend!!!
any ideas whats wrong, will have to drop car off again tomorrow i guess!!
thanks steve.
Reply By: Member - Steve T (NT) - Sunday, Apr 22, 2007 at 14:31
steve21
Sounds like you handbrake is over adjusted.
Jack up the wheel take it off, move the adjustment hole to the bottom, if you don't have an adjusting tool a flat head screw driver will do.
Loosen the adjustment, then adjust up untill you can feel it bind, then turn back 3 movements.
Cheers Steve.
235110
Reply By: Moose - Sunday, Apr 22, 2007 at 15:36
Steve
How tight is the handbrake lever? Had same problem once and just loosened it off a bit and problem solved. Either way it will undoubtedly be the handbrake that's the cause.
235118
Reply By: Member - Axle - Sunday, Apr 22, 2007 at 16:31
Or if its a cable set up, it could be siezed, kinked, on that side.
Axle.
235125
Reply By: nowimnumberone - Sunday, Apr 22, 2007 at 17:53
another problem i see on a lot of 80s and gqs are siezed rear calipers.
235134
Reply By: Sea-Dog - Monday, Apr 23, 2007 at 16:21
If your callipre isn't letting out enough you can always remove the squeal shims.. 80's aren't known for having noisy brakes and I have taken
mine out with absolutely no effect on the braking..
The new pads will obviously be a lot thicker than the worn ones and the new discs don't leave a lot of room as they are at full width...
I am thinking that your callipres are a bit sticky so start with the shims and go from there...
Could be as simple as getting a small G clamp and pressing your callipers all the way in so that any grit or whatever is moved aside and they may work as good as new.. could mean that you will have to get the callipers reconditioned also which is about $100 each..
Hope it is just the handbrake adjustment though..
235327
