toyota HJ75 Petrol - flat spot
Submitted: Sunday, Apr 22, 2007 at 19:30
Philip Tuffin
I have an annoying flat spot when altering the throttle at cruising speeds - sometimes while gently accelerating from stop. I have had the carby overhauled and replaced
fuel filters. The flat spot is more prominent when carrying a load. Do i start replacing things like the coil? Any ideas?
Reply By: MintabiePete - Sunday, Apr 22, 2007 at 20:20
Could be quite a few things , you say you have had the carbie done , but it could be quite easily the excellerator pump not delivering the right amount of
fuel when you put the foot down , it could be a spark plug breaking down under load , even a plug high tension wire breaking down . Sometimes you can pick it up immediatley , sometimes it takes time :)
235175
Follow Up By: Philip Tuffin - Sunday, Apr 22, 2007 at 22:32
Thanks for the advice - looks like I have a few jobs this week!
496228
Reply By: ross - Sunday, Apr 22, 2007 at 20:27
I had this and it was the diaphragm that opens up the secondary at about 1800 rpms. It costs about $30 for the part from memory.
It hangs off the front side of the carb. It doesnt get done in a rebuild unless you ask them.
Oh,and if its petrol ,its an FJ75;)
235177
Follow Up By: Philip Tuffin - Sunday, Apr 22, 2007 at 22:33
I'll check with the bloke who re-built the carby - thanks
496229
Follow Up By: V8Diesel - Monday, Apr 23, 2007 at 10:43
What Phil said.
If you give it a boot from idle and it still runs
well the accelerator pump works. If it runs OK main jet is clear which IMO leaves the vacuum secondaries (additional barrels) as the first point worthy of investigation.
496320
Reply By: Dunedigger - Tuesday, Apr 24, 2007 at 18:23
If you have a old style points spark system, try replacing the condenser. The condenser can give an impression of a carburetter flat spot. I have also had radio interference supression capacitors cause problems.
The second barrel sounds as though it may be the problem. Taking the air cleaner off and listening to the sound of the airflow will also tell you a lot. As the carburetter starts to starve, the sound if the hiss changes.
God, I love
fuel injection ! no more cold choke and no more flat spots ! ! ! ! !
Dunedigger
235578
Follow Up By: Member - Davoe (Nullagine) - Tuesday, Apr 24, 2007 at 19:37
Id like to see some
young ricer boy racer jump into an old carby vehicle and try and start t and take off full throttle ist thing on a winters morning
So many skills being lost - instead of wrestling with the 3 on the tree with no syncro into 1st its just d and away you go
496750
Follow Up By: Dunedigger - Tuesday, Apr 24, 2007 at 22:04
Syncro - - whats that ? ? ?
496794
