Sunday, Apr 29, 2007 at 15:03
Looks like there is an issue of sorts particularly is the container has previous held petrol:
Electricity in Petroleum
Fuel Systems address special precautions and design requirements involving loading rates, grounding, bonding, filter installation, conductivity additives and especially
the hazards associated with "switch loading." ["Switch Loading" is when a higher flash point product (such as diesel) is loaded into tanks previously containing a low flash point product (such as gasoline) and the electrical charge generated during loading of the diesel results in a static ignition of the vapor from the previous cargo (gasoline).]
Would be worth leaving those jerry cans with the lid off for a couple of days before putting diesel into them Steve.
Apparently diesel and, particularly, low sulphur diesel, is not a good conductor of electricity so tends to accumulate static charge and can develop quite a high potential which, eventually, will spark across to earth.
More research needed - hopefully someone on here knows about this area?
Mike Harding
497685
