stainless steel water tank
Submitted: Monday, Apr 30, 2007 at 02:48
ThreadID: 44897 Views:5131 Replies:9 FollowUps:8
Hi all,
Has anyone recently had a water tank custom made from stainless?
Was after rough ideas on cost and if anyone could recommend a good fabricator in Victoria!
Reply By: Member - Ruth D (QLD) - Monday, Apr 30, 2007 at 07:38
We had two 110l stainless tanks made for our homemade camper (each with two baffles) and they cost $455 each (in Queensland).
AnswerID: 236771
Follow Up By: Junior - Monday, Apr 30, 2007 at 15:52
Thanx Ruth- sounds fairly promising- mine should be around half the size, so hopefully about half the price! :-)
FollowupID: 497915
Reply By: Member - John - Monday, Apr 30, 2007 at 07:55
G'day, where abouts in Vic?
John and Jan
AnswerID: 236774
Follow Up By: Junior - Monday, Apr 30, 2007 at 15:41
se suburbs preferably John- I'm in Berwick/Beaconsfield
FollowupID: 497911
Reply By: Shaker - Monday, Apr 30, 2007 at 08:52
Mako Marine, Glendale Avenue, Hastings.
AnswerID: 236788
Follow Up By: Junior - Monday, Apr 30, 2007 at 15:53
thanx Shaker- will check them out
FollowupID: 497916
Reply By: Member - Doug T (W.A) - Monday, Apr 30, 2007 at 09:12
Go to a Truck accessory shop and get a Plastic 80lt [ good for drinking ] with a flat top or bottom , depends on how you mount it, I have been using one for 3 years ,
members.westnet.com.au/dtilley/4X4.htm and click the tank
AnswerID: 236793
Follow Up By: Junior - Monday, Apr 30, 2007 at 15:49
Hi Doug, has actually already checked out your site after going through archives!...
I've currently got a 20lt plastic one between back of fridge and cargo barrier and will continue to use multiple plastic water jerries as extra storage esp on longer trips. Mainly just trying to make efficient use of the already very limited space where my main "plumbed" water container is- I figure if I replace the 20lt jerry with a custom made jobbie, I should be able to get @ 40litres in there?!
FollowupID: 497914
Reply By: Keith_A (Qld) - Monday, Apr 30, 2007 at 16:40
Hi Junior - try any manufacturer in the food industry. All commercial kitchen and restaurant gear has to be stainless. The beekeeping industry uses all stainless equipment.
The Boating industry also (but often expensive).
If you ask at a local welding or Argon gas supplier, they should be able to tell you who the Stainless Steel firms are in the area.
Perhaps a Google or the yellow pages for a manufacturer...................Keith
AnswerID: 236873
Follow Up By: Junior - Tuesday, May 01, 2007 at 01:49
true about boating... grew up on and around yachts- you can sink a lot of money into 'em!!! (even more than 4wd's!)
but will try a few different places to get idea on price- thing with boating guys is they're likely to have easy access to welded hose fittings etc for water
gotta friend/client that is a cabinetmaker (kitchens)- should have some stainless contacts
FollowupID: 498068
Reply By: wdric - Monday, Apr 30, 2007 at 18:52
Longrange automotive make one to go up againts a cargo barrier.
I am sure they would even custom build one
AnswerID: 236912
Follow Up By: Junior - Tuesday, May 01, 2007 at 01:54
ta
FollowupID: 498070
Reply By: Ianw - Monday, Apr 30, 2007 at 19:49
G'day
I went to a motor wreckers and got a stainless LPG tank. Available from 60 to 110 litres cost virtually nil. In fact I got a 60 lt and an 80 litre for no cost. Just had to get rid of the LPG in the tanks. Kept the BBQ going for months!!! They have legal problems in disposing of the gas so are happy to give them away if they have gas in them. Only worth the scrap value of the SS to them. Very light when MT. Economical in space too, being round.
Ian
AnswerID: 236946
Reply By: Member - 'Lucy' - Monday, Apr 30, 2007 at 20:00
Brown Davis in Bayswater.
Deal only with Kevin Sharp the work shop manager.
AnswerID: 236951
Follow Up By: Junior - Tuesday, May 01, 2007 at 01:51
will call, thanx Lucy
FollowupID: 498069
Reply By: Member - cliff J (VIC) - Monday, Apr 30, 2007 at 20:51
hi there
sorry i can not help with someone to build tank i have s/s tank its fine now but when they made tank before i brought with camper they never put baffles in it first trip i used it split sides so make saw you get baffles put in i had to get them in when i got home
cheers cliff
AnswerID: 236968
Follow Up By: Junior - Tuesday, May 01, 2007 at 01:43
thanx Cliff, will do
FollowupID: 498067
