Safari Snorkels
Submitted: Tuesday, May 01, 2007 at 19:10
ThreadID: 44984 Views:4130 Replies:9 FollowUps:4
Hi there, again, I am fairly new to the world of four wheel driving however, are starting to venture into the unknown.
I have some cash to spend on my rig, a Series 2 TD5 Disco, and have been looking at a snorkel.
I don't know much about these but given we are travelling to Cooktown via the Bloomfield Track and hope to travel to the cape at a later date I was wondering whether this would be a worthwhile investment.
Any advise for the novice would be appreciated.
Your in anticipation
Cram (aka Marc)
Reply By: Voxson - Tuesday, May 01, 2007 at 19:14
Yep.. Get one..
AnswerID: 237210
Reply By: Martyn (WA) - Tuesday, May 01, 2007 at 19:29
Cram,
As per Voxson yeap get one by all means, but, the infamous "but" is this the first thing on your list? Or is this one of the latter things you are thinking of buying? I don't know anything about your rig and what you've done, one of my first things when I look at doing a good trip is decent tyres and top knotch suspension, maybe dual batteries, good driving lights. Oh I don't know, I just want to make sure your not maybe, you know, getting stuff in the wrong order. I'll more than likly get shot down in flames but this is my bit, the things I've suggested might cost a tad more than the snorkle as well. so yea, buy the snorkle.............
Keep the shiny side up
AnswerID: 237216
Follow Up By: Cram - Tuesday, May 01, 2007 at 19:35
Thanks for the advice. This is not he first thing I am getting I have about 4k to spend, thanks to a second job, I have already sorted the batteries and a few other essentials for the rig and trailer.
The snorkel was not on the list but after reading some stuff on here about our planned trip I thought it may be worth it given I will be crossing some water.
FollowupID: 498228
Reply By: Mobi Condo - Tuesday, May 01, 2007 at 19:38
Regards Snorkel only here - we just had a Safari fitted to our 80 Series due to an impending trip to the Kimberly region (potential water crossing we felt).
Why Safari - it appears to be the one on the 80 Series with the most direct (least convoluted pathway through the fender void) and also the more secure "coupling" arrangement. 'Twas a tad more pricey than others we researched though.
Cheers - Mobi
AnswerID: 237219
Follow Up By: Cram - Tuesday, May 01, 2007 at 19:41
The prices I have had are $690 (fitted) for he safari snorkel. TJM have one they supply for $650 (fitted) so not a lot in the price.
FollowupID: 498233
Follow Up By: Martyn (WA) - Tuesday, May 01, 2007 at 19:44
Agree, I have a genuine Nissan one on my Patrol and I had the Safari on my old GQ, the genuine Nissan one can't be turned 180 degrees in very dusty conditions I suspect that's why one is cheaper than the other. Both took the same route and were a pr!ck to fit.
I would also go the Safari, you can fit socks into them as well to act as a prefilter for the big stuff, flys, bees, birds, moths etc.
FollowupID: 498238
Reply By: On Patrol (Aust.) - Tuesday, May 01, 2007 at 19:40
Get one Cram, you would also know that they are not just for water crossings but help your motor breath cleaner air from higher up in dusty conditions.
Colin
AnswerID: 237221
Follow Up By: Cram - Tuesday, May 01, 2007 at 19:42
Yeah, thats what I have been led to believe, thanks.
FollowupID: 498236
Reply By: Sand Man (SA) - Tuesday, May 01, 2007 at 20:11
It wouldn't be a priority investment I would make.
You certainly don't need it to travel the Bloomfield Track in reasonable conditions, correct tide etc., it is a relatively straight drive. Hell, I did it in a Hyundai Santa Fe which doesn't have a low range.
The two main crossings are at Woobadda Creek (very difficult in the wet) and Bloomfield River Crossing (normally dry causeway crossing but sometimes impassable in the wet when the crossing is under considerable water.
If the water was deep enough to require a snorkel then the actual flow of water would stop me from trying. Several vehicles have come to grief on the Bloomfield Crossing, with or without a snorkel, by being swept off the concrete causeway by the force of the water.
Just my thoughts!
Bill
AnswerID: 237238
Reply By: mike w (WA) - Tuesday, May 01, 2007 at 21:57
Some sound replies above.
Unfortunately not knowing your vehicle's quirks, I can not comment on that side. However I do own a safari snorkel on my rodeo. It was one of the first things I fitted as the air pickup was in a rediculous spot above the guard and used to suck in alot of dust. Also the price was good, about $560 fitted from opposite lock (from memory) They were cheaper than some of the others e.g. ARB.
You could pick worse things to get fitted.
AnswerID: 237284
Reply By: bockstar1 - Wednesday, May 02, 2007 at 08:22
Morning
Seriously consider joining a club and doing some sort of driver training.
AnswerID: 237344
Reply By: Gossy - Wednesday, May 02, 2007 at 09:06
definately fit one but don't do it yourself. Putting the foot end of a stocking on the end saves alot of bugs getting into your airfilter also. Don't have to spend money on those dedicated attachements that are around these days. Old stocking foot does exactly the same job without impeding the air flow.
AnswerID: 237356
Reply By: Member - Dazza- Wednesday, May 02, 2007 at 19:51
I've found snorkels to be of use in water crossings, sand and dust.
For water, make sure the installation is water-tight or it's a waste of time. Block the ends and pressurise it to be sure. For water the type of snorkel probably doesn't matter as long as it is well fitted.
The Safari with it's vertical top section wins in sand and dust.
In sand dunes you will occasionally have the front wheels throw up sand, and turning the cap to face rearwards will stop it going down the spout.
In dust a centrifugal / spinner type cap stops a hell of a lot of dirt before it gets to load up the air filter. It's easy to just empty out a cupful of dirt each evening, and you'll be amazed how clean the airfilter stays.
Dazza
AnswerID: 237486
