GU Patrol
Submitted: Tuesday, May 01, 2007 at 22:33
out_n_bout
I'm looking at a 2000 4.2 litre Turbo Diesel ST Patrol that has 130,000km's on the clock and has an asking price of $30,000 on it. Can anyone tell me if this is a good price for this vehicle please.
Serviced every 5,000km's
Central Locking, Disc Brakes Front Ventilated, Disc Brakes Rear Solid, Engine Immobiliser, Flares, Limited Slip Diffs, Power Antenna, Power Door Mirrors, Power Windows - Front & Rear, Side Steps, Sports Instruments, ARB winch Bar (no winch),
Snorkel and
Driving Lights.
Reply By: Member - Roachie (SA) - Tuesday, May 01, 2007 at 22:42
I just sold my 2000 4.2TD (which I'd owned since brand new), for $23,000-. It had a ARB winch bar (no winch), dual batteries and additional wiring etc, Safari
Snorkel, towbar etc. But it had done 212,000klm.
Most of the "extras" you listed are standard equipment; but I'm not quite sure what "sports instrumentation" means?
$30K is probably a bit over the top, but then again it doesn't have too many klicks under it's belt. If you like the vehicle and intend to keep it for quite a few years, then I would say go for it. It will go for yonks.
Check underneath to see if there is any signs of it having been abused off road.
Good luck......
Roachie
237302
Reply By: Michael ( Moss Vale NSW) - Tuesday, May 01, 2007 at 22:46
Check out post 44990, just yesterday i think, similar vehicle 1999 GU 4.2 td, the general view was around $27,000 but Roachie may be right, it really depends on demand but the 4.2 with low ks is a good bargaining tool.. Michael
237305
Reply By: joc45 - Tuesday, May 01, 2007 at 22:57
The 2000 4.2's also had the 5th gear problem (as I found out on
mine). Could be worth checking if the previous owner had probs with it. If it had never towed, the problem would most likely not have come up.
As said, most of the "extras" were standard on that model.
If in WA, you could possibly have to pay something around that price. Better s/h prices over east.
Gerry
237312
Reply By: barney rubble - Tuesday, May 01, 2007 at 22:57
Gday mate just for your comparisan we just got a 2003 4.2 intercooled turbo with bullbar / winch / cargo barrier but otherwise the poverty pak with 11000km on her for 42 g
check out action motors in
perth or even the website has a good range of patrols to compare with hope this helps Cheers
237313
Reply By: zad - Wednesday, May 02, 2007 at 00:13
I've just bought (
well, take delivery on Thurs morning) a 2002 GU III Patrol 4.2 t/d ST for $36k. It has 119000 kms on the clock, has dual batteries, rear drawer system, milford barrier, ARB winch compat bullbat, sidesteps, etc. I was a bit nervous at first about the dollars being spent on a 5 year
old car, but realised I wasn't able to find anything else with that motor for under that. According to the prices you guys are quoting, sounds like I've bought on about the right money (although my financier's database puts the vehicles value back to about $29k - just goes to show how good these databases are).
237321
Reply By: Member - Duncs - Wednesday, May 02, 2007 at 07:47
Based on what Zad has said it looks like you might be on to something. It is about the same vehicle as Zad has boght but without the accessories.
Having previously bought a vehicle 2nd hand that was fully set up you have to ask, why did they set it up like that? The answer is usually that they did it to use it.
If you buy the one you have seen for 6g less it is less likely to have done much off road, therefore less likely to have been knocked about. You then have 6g to put on the gear you want.
Duncs
237338
Reply By: uneekwahn - Wednesday, May 02, 2007 at 07:55
I just picked up a 2001 GUII 4.2ltr TD with
snorkel, dual batteries, factory rear airconditioning (in a different location to the TI), two LCD screens, DVD player, infrared headphones, 2 spares and 96,000km for $34,000 here in
Perth.
237340
Reply By: Member - Sam (NSW) - Wednesday, May 02, 2007 at 08:37
I picked up my GUII 4.2TD ST in August 2005 for around $35k (factory bull bar, warn 9000lb winch, alloy luggage rack, tow bar) with 60k on the clock (ex government). been going strong ever since and is nearing 100,000kms on the clock
237348
Reply By: Trevor R (QLD) - Wednesday, May 02, 2007 at 08:46
I would have thought it to be valued at 23-27K. Check the 5th gear as it is a prob with this year model.
Cheers, Trevor.
237349
Reply By: downtools - Wednesday, May 02, 2007 at 10:12
out_n_bout,
This may be of some help, the more comparisons you can get the better!
We bought a 2004 GUIII ST march last year with 42,000 klms for $43K.
It came with ARB winch bar, no winch.
Kaymar duel wheel carrier, two spares, cargo barrier in spotlesss nick!
Had the diesel tuned by Berrima, changed the
suspension and am very happy!!
Good luck, you can't go wrong.(with a Nissan 4.2)
Nifty
237367
