Nissan GQ Series - Problem rear door
Submitted: Friday, May 04, 2007 at 18:58
TheMajor
My mate recently discovered a problem with the driver side rear door (the one that holds the spare wheel) in that the small metal door stopper (I am not sure if that is the proper description) situated between the two hinges and fitted between the rear door and the cabin had broken. This connecting bar had come adrift from the inside panel weld of the vehicle, not the door. It would seem you can get access through the tail light, however, I was wondering if anyone else has had this sort of problem and is there a quick easy fix or remedy. Sorry about the description but I am sure Nissan owners will be able to visualise the area I am referring to. Any information will be greatly appreciated.
Thanking you in anticipation
The Major
Reply By: Member - stefan P (NSW) - Friday, May 04, 2007 at 21:20
Had the same issue with my GU when I bought it, It had to be re welded and re painted...It was warranty work so no idea of cost
Cheers Stefan
237953
Reply By: Member - Ed. C. (QLD) - Friday, May 04, 2007 at 21:39
Yep, my GU did that....
2x 6mm bolts & nyloc nuts, and she ain't comin' loose no more no more;-)))...........
(and yes, ya need to remove the tail-light to get in there)......
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
237962
Reply By: ferris - Sunday, May 06, 2007 at 22:39
Yep, so did my first GU. A friend welded it for me, and we saved the paint work by placing a wet rag on the otherside of the weld.
238303
Reply By: TheMajor - Monday, May 07, 2007 at 20:20
Thanks very much fellas for the information. It seems from your comments it is a common problem. I certainly appreciate the advice and I have already passed it on to my mate.
Cheers and once again Thank You
The Major
238451
