Computer prob's follow up
Submitted: Sunday, May 20, 2007 at 14:19
Dave Thomson
Hi All ,further to Dougs" computer prob" the other day I wondered how many of us were guilty of a booboo like that ? I know I spent over an hour at a friends last week trying to fathom out why her sound had disappered I checked the sound card tested everything connected with it even to the point of making sure the speakers were wired up correctly only to find out after an hour she'd hit the mute button by mistake !!! DOHHH...................
Reply By: warfer69 - Sunday, May 20, 2007 at 14:26
Yep the Mute Trojan will do that !
241175
Reply By: Member - Dunworkin (WA) - Sunday, May 20, 2007 at 15:25
Yep been there done that.
D
241178
Reply By: Member - Doug T (W.A) - Sunday, May 20, 2007 at 15:43
Well there ya go all , I'm not alone after all , There are other D/Heads i can now associate with, ......lmao
Doug
241184
Reply By: DIO - Sunday, May 20, 2007 at 17:46
My experience with computers over some 20 years has taught me that many problems with them are the result of silly/simple errors caused by the operator/user. Best advice is to always look for the most obvious solution which is generally the simplest most expedient to resolve any problems. Too many 'gurus' will tell you that the first thing you need to do is re-format the hard drive. WRONG, that would be the very last thing I would even consider let alone do. A bit like vehicles, you don't have to be an expert to use them or fix them, HOWEVER there comes a time when it's absolutely time for some professional intervention.
Remember - 'if it ain't broke - don't fix it'.
241211
Follow Up By: Waynepd (NSW) - Monday, May 21, 2007 at 09:51
The most obvious problem is usually code-named by Tech Support Personnel as PEBKAC (or Problem Exists Between Keyboard And Chair)
502306
Reply By: pjchris - Sunday, May 20, 2007 at 20:14
I can remember three such incidents from when I worked as an on call technician...
Once I was called out desperately to fix a computer that was used in the Page Layout department of a
Melbourne periodical publisher to fix an A4 portrait monitor taht would not work....I sat down....saw that the power light was on....turned up the brightness.... All was good....
Another time I was called out on a Saturday morning (At some ridiculous rate) to fix a Mac at a travel Agents in
Melbourne's east only to find that they had plugged a serial cable into the SCSI port (For external Hard drives etc).
And finally a friend was called out two weeks in a row to a company to fix a broken monitor...On arrival (same monitor both times) he found that the power cord was unplugged from the power point....Seems the cleaner was unplugging it to use his Vacuum cleaner and not plugging the monitor back in again afterwards.
241250
