Diesel Gas
Submitted: Thursday, May 24, 2007 at 17:55
redfive
Gentleman
Anyone out there done it i was reading there website the other day sounds interesting
www.dieselgas.com.au/home.htm
i own a 2002 troopy 1HZ just thinking it will make it go better maybe? clean up the oil (longer
services)and should be cheaper to run maybe?
give me your thought
Glenn...
Reply By: Member - bill - Thursday, May 24, 2007 at 18:44
yes we had it done very happy with the system better towing longer range just easier to drive we have a after market turbo as
well
242085
Follow Up By: Mayesy - Thursday, May 24, 2007 at 18:48
Bill I have after market (safari) turbo fitted to my 1hz. 100 series. Do you notice an improvement in the economy and is there any significant power increase. Do you have any stats?
Geoff
503097
Follow Up By: Member - bill - Thursday, May 24, 2007 at 20:41
we have done about 36000 k a lot of it towing a van kept some stats early on but found it waste of time as u get to destination take of van and go for spin u just could not keep track of it sorry could not help u better bill
503127
Reply By: Dunedigger - Thursday, May 24, 2007 at 19:38
Yep, Had my 2003 79 done. It it a factory turbo. Lots more grunt perhaps a saving on 1 litre per 100 km . . but the power to tow is awesome . . I tow a large horse-float and overtake all the semis up the hills AND in a higher gear.
Lots less gear changes.
I can''t recommend it though if you want to save money.
The 4.2 Nissan does really benefit from it though due to it's indirect injection.
If you just want grunt, then a Dtronic may be the way to go. I have . . . both.
Now I have to watch for speeding tickets . . nearly was 'got' a few weeks ago
Dunedigger
242106
Follow Up By: Member - lyndon K (SA) - Thursday, May 24, 2007 at 20:57
Umm, Better
fuel economy, LPG = about a 70c/ltr saving. Why no cost saving?
Please explain.
Thanks Lyndon
503133
Follow Up By: Member - lyndon K (SA) - Thursday, May 24, 2007 at 21:42
Any pic's of the instilation would be great. Ta
503153
Follow Up By: Dunedigger - Tuesday, May 29, 2007 at 14:06
Sorry I have been away for the WE.
A bit pointless taking photos. The system is really very simple.
Tank under tray, Gas converter next to sidewall that looks just like a car gas converter (
water heated ) a boost detector fitted on the air inlet after the turbo to turn on gas, and a stepper motor that is controlled by a computer that I think takes info from the leads going to the car computer.
After control by the stepper motor the gas goes into the air inlet before the turbo.
Yes I would say it has increased my range by 200 Km.
i now am looking at fitting a larger exaust IF it gives me more power only between 2000 - 3000 RPM
504143
Reply By: ellmcg - Thursday, May 24, 2007 at 20:43
Has anyone got some economics on this? - set-up cost, diesel
fuel efficiency, diesel+gas
fuel efficiency
242148
Follow Up By: Member - lyndon K (SA) - Thursday, May 24, 2007 at 20:59
Yep, i wish to know to please.
503134
Follow Up By: Member - andrew B (Kununurra) - Friday, May 25, 2007 at 07:20
Since I have had
mine done, I basically use the same volume of
fuel, around 15l / 100km. Now 4l of that is lpg. at 50 odd cents per litreits a saving of $2.00 per 100km. after fed and WA rebates cost me $1200.00.
This equates to 60,000 km to pay back. Not too bad, considering I have increased my range by 200 km (approx 28 litre
tank) and gained about 15 % in power across most of the rev range (dyno).
Without the WA rebate of $1k, about 110,000 km to cover the cost.
Cheers Andrew
503195
Reply By: Dallas from Team Green Autogas - Sunday, May 27, 2007 at 15:48
G'day Redfive,
We've done a 2004 HJ75 with the 1HD Turbo Charged Stretched 'Cruiser. We picked up around 20% at the rear
wheels & approx 20% increase in economy at the same time. It came up a realy nice fit.
Dallas Green
242703
