Tyres Question
Submitted: Sunday, May 27, 2007 at 15:14
ThreadID: 45947 Views:2879 Replies:5 FollowUps:4
I am looking to pick up a set of tyres for the 80 series and I have always used Dunlop Road Grippers 7.50R16 over the years with no complaints. In searching for a set of near new second hand ones I have found a couple of sets that are 205R16 am l correct in assuming that these are a little wider?
Regards.
Steven
Reply By: Member - Tour Boy- Sunday, May 27, 2007 at 15:22
HI mate,
I think from memory that the 205's are the hilux size and are smaller in diameter. You need 235-85-16 to be the same as the 750-16's
Tour Boy
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 242696
Follow Up By: Member - Ian H (NSW) - Sunday, May 27, 2007 at 17:00
Yes, you are 100% correct. 235/85x16 are the same diameter as 750/16. 750/16 are 812mm diam and 235/85x16 are 809mm diam, so close enough.
FollowupID: 503705
Reply By: Member - Duncs - Sunday, May 27, 2007 at 15:24
According to my ruler 7.5 inches is 190mm. I would therefore assume that 205mm tyre is wider, approximately 8 inches.
Duncs
AnswerID: 242697
Reply By: LCRUZA (VIC) - Sunday, May 27, 2007 at 15:56
There is a tyre size calculator on this site Site Link
Ron
AnswerID: 242705
Reply By: Member - Phil G (SA) - Sunday, May 27, 2007 at 18:55
Theres a huge difference in diameter - 750mm vs 810mm, so the 205's would be considerably undersized for your 80series. If you want a wider tyre for your split rims, 235/85R16 is the go.
AnswerID: 242728
Follow Up By: Member - Steven H (ACT) - Sunday, May 27, 2007 at 19:28
Thanks Phil.
FollowupID: 503740
Reply By: Footloose - Sunday, May 27, 2007 at 19:08
Pity you're in the ACT. I have a new set just sitting here gathering spiders. Complete with new tubes. 7.50X16
AnswerID: 242733
Sounds good but i am assuming you are far far away?
FollowupID: 503739
Follow Up By: Footloose - Sunday, May 27, 2007 at 19:35
Sadly yes, Gold Coast Qld.
FollowupID: 503747
