Information needed on Navara
Submitted: Saturday, Jun 02, 2007 at 18:16
Vince NSW
Picked up the New D22 this morning. Fitted the HF behind the rea
seat in the dual cab.
Question for all you Navara owners. How do I get the cables from the engin bay to the cab. There seems to be a lack of openings through the fire wall.
Vince
Reply By: Member - DAZA (QLD) - Saturday, Jun 02, 2007 at 19:40
Hi Vince
On the driver side of the fire wall you will find cables going through a rubber grummet I managed to get our positive & negative cables through with enough
room for the coax aerial.
I then got all the cables under the dash and hid them under the gear stick consul
between the bucket seats, we fastened the radio to the back of the centre consul,
it looks like a factory installation. cant see any cables all hidden.
Daza
244229
Follow Up By: Vince NSW - Sunday, Jun 03, 2007 at 17:14
Thanks Daza,
Got it in this morning + extra cables for power to the rear of the Ute tub.
Thanks for you help
Vince
505349
Reply By: jon p qld - Sunday, Jun 03, 2007 at 07:31
As mentioned above use the big groumet where the main wiring loom enters the cab through the firewall just below the brake master cyl. A bit tricky to get to, but do be careful you don't damage any of the wiring in the loom as a lot of weird electronic malfunctions have been traced back to damaged wires where this has been used as an access point to the cab for spot light switches etc.
Regards Jon
244283
Follow Up By: Vince NSW - Sunday, Jun 03, 2007 at 17:15
Thanks Jon, got it in this morning
Vince
505350
