145 Liter water tank with 5 yrs NO PLASTIC TASTE guaranteed
Submitted: Saturday, Jun 02, 2007 at 21:20
Saudi Camper
Hi to you all …..
I’m a new member to this great website from Saudi Arabia and I am into
camping big time.
I’d like to share with you my experience with a 145 Liter
water tanks I purchased last year.
And its features are:
145 liter * 5 yrs NO PLASTIC TASTE guaranteed * 12 kg weight * made of Polyethylene * 7 mm thickness * suits all sort of 4WD vehicles.
The price was 450 $ (Australian Dollars)
Dimensions: Length 950 mm Height 530 mm Width (top) 200 mm (bottom) 400mm
What do you all think of it and is the price competitive to the price in Australia? Your feedback highly appreciated.
check out this link of pictures i know you guys might not know Arabic language but you can just check out the pics.
" target="EOF" class="lbg">Site Link
thanks,
Saudi Camper
Reply By: oldpop - Saturday, Jun 02, 2007 at 21:32
Hi Saudi Camper
Looks Good Not sure about price how many camels does it feed LOL
Regards Old pop
244256
Follow Up By: Saudi Camper - Sunday, Jun 03, 2007 at 00:33
Dear Oldpop
I really like your comment.... lol ... i'll check that for you lol
505245
Reply By: Member - JohnR (Vic)&Moses - Saturday, Jun 02, 2007 at 22:58
Saudi Camper, it looks a pretty solid piece of gear and I would have thought price competitive. There are quite a few options for
water tanks, but I don't think I have seen one like that. It would be better I would have though to keep the weight lower and forward if posible, but I know you can't always do that. In some ways, good behind the rear
seat.
Does it have an internal baffle so the
water doesn't slop around inside?
244263
Follow Up By: Saudi Camper - Sunday, Jun 03, 2007 at 00:45
Dear JohnR
as far as ther wieght is concened i believe it's not an issue ..
regarding the baffles... it has none.
but let me tell you something the
tank is very heavy duty and tough i have hit the
tank with a hammer as hard as could .. and guess what .. the
tank did not break at all.
thanks.
505246
Follow Up By: Member - JohnR (Vic)&Moses - Sunday, Jun 03, 2007 at 08:16
SCamper the issue of the baffles is just something to be wary of in unstable conditions with a 3/4
tank of
water where the shift in weight can be sudden to the outside of a curve or your downhill side reducing the surety you feel driving,
Keep safe.
505258
Reply By: Member - Doug T (W.A) - Saturday, Jun 02, 2007 at 23:10
Saudi Camper
I have one 80 ltr plastic
tank in my Landcruiser, it cost A$110, I could fit another and have 160lts for $220 . the link shows what they look like with specs.
www.bmackay.com.au/dp/
tank.html
Doug
244265
Follow Up By: Saudi Camper - Sunday, Jun 03, 2007 at 00:47
dear Doug
i have seen alot of
water tanks types but this one does not take up space as the others do since it slides up behind the middle
seat.
thanks
505247
Follow Up By: Tim HJ61 (WA) - Sunday, Jun 03, 2007 at 11:00
I'd be guessing you don't have to mount them with the curved side down, as under a truck tray, as there is a bung top and bottom. they could sit 'upsidedown' with outlets leading to a nice pressure pump in the back of a wagon.
Tim
505283
Follow Up By: Member - Doug T (W.A) - Sunday, Jun 03, 2007 at 11:57
Tim
That is correct Tim, I have
mine as per the photo above, the top outlet is breather only, the must be able to expel air when filling yje way I do it, and also must be able inhale as
water is used, so my at my outlet I have a T piece, one to the tap for gravity feed and reverse fill and the other to a pump for showering, not this time of year though BBbbrrrrr , The breather I have fitted a hose to a tap with clip on fitting and small tap so I can turn off the breather if needed, I connect a short piece of garden hose to it when filling so when it is full the
water don't end up inside the car ,so when the
tank is filled to capacity I turn breather of so it don't also run out as if going up a steep dune etc , after the level gets down I leave it open , See the photo's of the taps and where my
tank is
Site Link
Doug
505291
Reply By: Saudi Camper - Sunday, Jun 03, 2007 at 01:18
Doug
can you show up pictures of the tanks in your car and how they are set up inside your car.
thanks.
244277
Reply By: DIO - Sunday, Jun 03, 2007 at 10:58
Great photos, looks pretty secure with cables and turn buckles. For those of you with Internet Explorer V7 (or so), when viewing the link site, RIGHT CLICK the mouse button and select Translate into English. The translation is pretty literal however it gives you a bit of an idea on the thread.
244318
Reply By: Saudi Camper - Sunday, Jun 03, 2007 at 20:08
dear all
thanks for the replies.
i have one important question for you all
the
tank has no baffles so here goes my questions
how important are the baffles in a 145 liter
water tank?is it dangerous since it has no baffles? are baffles a must ? will you go for this
tank ? will you pay 450$ for it or you think it's expansive? and if you think it's expansive how much would you pay for it?
i thought i had only one question but somehow it became 6 questios. sorry :)
replies are appreciated?
Saui Camper
244478
