MLR 24 SP GPS serial connector....
Submitted: Tuesday, Jun 05, 2007 at 13:14
ThreadID: 46303 Views:7939 Replies:4 FollowUps:3
A begging question but does anyone out there have an MLR SP 24 hand held GPS or more specifically the manual that accompanied this device.
I have had mine for about 7 years using it sipmly for lat/long navigation but now wish to connect it to the laptop via the serial port for OziExp type mapping. I have the cable that was supplied new with the unit which plugs to the back of the GPS but the cable end was not wired to a serial port connector. Instead it simply had a schematic of what colour wire goes to which pin in the plug, buried in the instruction manual.
As I've put my manual in a safe place, which means it is now very very very safe, I wonder of anyone can help me with the detail of which wire goes to which pin.
Reply By: Gob & Denny - Tuesday, Jun 05, 2007 at 13:42
gooday john
i dont have amanual but if you tell me where your safe place is i will try and remember wher mine is
safe places are really safe sometimes, i find year by year they become safer???
steve
AnswerID: 244888
Reply By: SCUBADOO - Tuesday, Jun 05, 2007 at 14:45
Easy:
GOOGLE GOOGLE GOOGLE
eg. Site Link may help.
Neville
AnswerID: 244901
Follow Up By: Member - John L G - Tuesday, Jun 05, 2007 at 14:55
Scubadoo
I'm impressed and ever so humble.
Have spent the last two hours Googling away and got all sorts of info but obviously not that one, which of course is exactly what I was looking for.
Many thanks for the heads up and once again the font of knowledge here never ceases to impress.
John G
FollowupID: 505981
Reply By: Jagg - Tuesday, Jun 05, 2007 at 19:49
See info below off the internet........hope it helps. Geoff
In a recent message, Me2aswellwrote.
>Help...I have lost my Manual and cant find the manual on the net. I need the
>wiring diagram for a power plug and a serial cable.
The basic cable is as follows:
DB9 PC PIN SP24 PIN COLOUR OF WIRE SP24
2 3 Orange
3 4 Yellow
5 5 Blue
The socket on the back of the SP24 is arranged thus:
EXT ANT POWER SUPPLY PIN 1 BROWN
POWER SUPPLY + (10 TO 20 VOLTS) PIN 2 RED
POWER SUPPLY - PIN 5 BLUE
NMEA OUTPUT PIN 3 ORANGE
NMEA INPUT PIN 4 YELLOW
The pins are numbered clockwise starting with 1 which is to the left of the larger of the three notches (the bottom pin, if you hold the SP24 upright in front of you).
Just repeating what it says in the manual, can't vouch for the info, I'm afraid. Hope this helps.
AnswerID: 244990
Follow Up By: Member - John L G - Wednesday, Jun 06, 2007 at 07:35
Geoff
Thanks for the input and seems to confirm that I need to learn the Google Mastering a bit more.
Have had a good look at the MLR and all this seems to make sense when I look at 9pin serial port configurations for data connections so will have a play tonight when I have some time and see if the whole thing works.
Of course, next I will be on here pleading for help with OziExplorer, but we will come to that hurdle when I get there.
FollowupID: 506145
Reply By: luxtourer - Sunday, Jun 10, 2007 at 12:57
Hi John
I think you already have the info you were looking for, but I do have a manual for the SP24 if there's other info you need.
Cheers, John
AnswerID: 245878
Follow Up By: Member - John L G - Monday, Jun 11, 2007 at 12:13
Thanks for the follow up and yes the previous responses helped a lot.
I finally found out that MLR were taken over by Thane Navigation who in turn produce the Magellan range of GPS. I emailed them my problem and they were pretty quick in emailing me back a PDF file of the manual. I think it's there because the guvvy computer I'm on wont let me open it through my private web server, so hope it was what I was looking for.
I'm pretty particular about equipment files and have file manuals on all the gizmos I've purchased over the years however the MLR manual seems to have found another life and left home.
Thanks for the input and if I can't open the file may be back to you soon through this web site.
JG
FollowupID: 506977
