Tyre pressures Roadgrippers
Submitted: Wednesday, Jun 06, 2007 at 16:45
Member - Geoff C (QLD)
My 2003 Patrol ute has Dunlop Roadgrippers front and back, F on front and S on the back. The pressure info inside the glove box says they should be 51lb and 68lb respectively. This seems very hard to me so I have been running them 38lb and 52lb. The ute carries about 500kg (swmbo does not travel light) and we tow a caravan about 2000kg. What is a reasonable pressure to run them at as best for tar and also for dirt roads?
Thanks, Geoff
Reply By: obee - Wednesday, Jun 06, 2007 at 18:00
I have used grippers on my hilux and I noted that toyota specs seemed a bit low so I ran them mostly around 30psi and they still wore mainly on the centre. I am nowrunning a bit lower on a pair to even it up as they get close to retirement. Meanwhile the kuhmos run thirty but wore on the outside so I have them on 45psi to wear the centres down.
Point is I think it all depends on the tyre manufacturer rather than the vehicle maker. That and the type of use they get. I would ask the local retailer what they recommend because they get to what happens to them.
Thats my experience anyway.
Owen
245179
Reply By: Peter 2 - Wednesday, Jun 06, 2007 at 18:41
Geoff
Would I be correct in that from memory the F is a 7.50 x 16 and the S is a 235 x 16?
If so I ran both on a troopy over a 10 year span, the 7.50's come in either a 6 ply or 8 ply and the 235's are roughly equivalent to a 6 ply.
On the troopy laden I ran up to 55 psi rear and always around 40 front with the 7.50's and achieved even wear.
The 235's are a lighter tyre and are normally fitted to the base model 100 series. I ran them at a lower pressure as they have a lower load rating and are also have a lighter more flexible wall. Pressures I ran with the 235's were around 40 on the front and 45 on the rear but dropped them further (and dropped the speed further) on rocky roads than the 7.50's due to the lighter construction.
The 235's were an excellent highway and sand tyre but being softer in the walls I was always carefull in rocky country
245192
Follow Up By: Member - Geoff C (QLD) - Wednesday, Jun 06, 2007 at 19:25
My s tyres are labelled 7.50R16LT. They have a different tread pattern than the F type. Maybe I should swap them to the front as they seem to be wearing quicker than the F type.
Geoff
506289
Follow Up By: Richard Kovac - Wednesday, Jun 06, 2007 at 22:01
Peter / Geoff
Im running the 235/85R16 this time around (not many rocks in WA) lots of sand, run the same as you did Peter both "F" & "S" 40psi front and 55psi rear loaded most of the time 3.3 tonne
Tyres have never let ne down only the tubes LOL
Richard
506323
Reply By: sailor1man - Wednesday, Jun 06, 2007 at 22:18
Tyre pressures! Its easy you use the 4 PSI rule. I drive a GUIV Patrol and normally run 35PSI, towing a heavy trailer I go up to 45 in the back and 40 in the front. Using the 4 psi rule. Check tyre pressures first thing in the morning when tyres are cold ( no good driving down the service station then checking them they warm up pretty quick and use your own gauge to be consistent) Then after driving about 50k or more stop and immediately check the pressures. It should have risen by 4 PSI. If not your tyres are over inflated, If they have risen by more than 4psi they are under inflated.
245269
