air tank??
Submitted: Sunday, Jun 10, 2007 at 13:22
tvl
hi everyone'' just cut one of those stainless steel coke kegs in half /drilled
some holes in the bottom,and stuck it to back of boat(berley pot)should
work
well,anyway i was thinking ,that would make a good storage
tank
for continous air running full time ,as it already has pressure valve built
in,cant rust ,sorta small,and cheap to buy.anyone done this with a
tank
like that???the
tank holds 90psi max .
Reply By: louie the fly - Sunday, Jun 10, 2007 at 13:31
how you going to fill the
tank, from a compressor? FYI, just remember, air from an oil lubricated compressor can (read will) give you cancer. If you can fill it from your tyre inflating compressor it would probably work. Make sure its sucking clean air, i.e. no CO or other toxins. I have a calculation somewhere for working out the consumption rate for a human. It's somewhere around 20L/min @ 14.7psig. If your
tank holds 90 psi and 50 litres then the volume expanded back to atmospheric pressure is quite large. Why you want to do this anyway?
245881
Follow Up By: Mikee5 (QLD) - Sunday, Jun 10, 2007 at 16:12
I don't think it would matter when blowing up tyres.
506874
Follow Up By: louie the fly - Sunday, Jun 10, 2007 at 16:24
Yeah. Don't know why but I made an assumption that he was going to use it for diving or something. Must have been something to do with the mention of a boat.
Feel like a bit of a D/head but anyway.
506876
Follow Up By: tvl - Sunday, Jun 10, 2007 at 17:42
louie,, your not a di//head .thanks for advice ////
506884
Reply By: Member - Ian F (WA) - Sunday, Jun 10, 2007 at 13:34
Hi, you want to be very carefull with this type of unit especially with the rules and regs now we all have to put up with even though you have a regulator valve. It is just that I have been with the Mining Industry for years and the govt health and safety take a dim view of this.
I know it also seems to be over regulated and I am staring to think its about time I retired as I have had enough and one is not allowed to use common sense any more.
Ian
245882
Follow Up By: goingplatinumcomau - Sunday, Jun 10, 2007 at 22:34
Aint that the truth over regulated i wonder if anyone has ever calculted the lost time through there over the top WP/HSafety.
regards John
506937
Reply By: mike w (WA) - Sunday, Jun 10, 2007 at 15:20
90 psi is 90psi, you need to be more concerned regarding the actual volume, not the pressure.
I was looking at doing the same sort of thing with CO2 fire extinguishers, however with all the mucking about and the likes, you can get application specific pressure vessels with gauge and pressure releif valaves from
places such as bunnings and tool shops for $50 on sale. Alot less mucking about, not that Im knocking your idea, just look at the practicalities.
On another note, everyone in the east must be away for the public hliday eh??
245901
Follow Up By: tvl - Sunday, Jun 10, 2007 at 15:34
not away, at bunnings looking for heaters!!its bloody freezing!!
dropped down to 15 deg last nite...........
506862
Follow Up By: mike w (WA) - Sunday, Jun 10, 2007 at 15:50
Ha ha, sunny and low 20's in the west....
mmmm, shorts and tshirt LOL
506868
Follow Up By: Member - Effie C (ACT) - Sunday, Jun 10, 2007 at 22:12
Oh I wish it would even get to 15 C in the day time!!
506934
