Starter Solenoid
Submitted: Tuesday, Jun 12, 2007 at 08:57
Ray Bates
Well howdy,
I have been chasing a solenoid switch for a starter motor for a FJ 80. Although this part is shewn in the Toyota spare parts list complete with its own part number I was told that Toyota no longer sell the solenoid as a separate item. Any advice from you guys would be appreciated.
Thank you
P.S. I have tried Repco and Coventrys
Reply By: darcla - Tuesday, Jun 12, 2007 at 09:26
Hi Ray
If it's what I think the contacts not making contact with the poles because they have burnt away over time, you can build them up with silver solder & they will last for years. Or you should be able to get a new one through a good auto sparkie.
Cheers Bungarra
246273
Reply By: Mark Taylor - Tuesday, Jun 12, 2007 at 12:35
Virtualy all auto electricians could rebuild this for you if the problem is contacts burnt out. When I worked on the
tools I rebuilt many solenoids.. or replaced the U/S ones with non genuine units from Ashdowns and the like.
Mark T
246298
Reply By: Member - Phil G (SA) - Tuesday, Jun 12, 2007 at 14:33
You should be able to source the solenoid contacts via an auto electrician. Its an easy job to remove the solenoid cover to replace the burnt contacts.
246311
