Cruiser diffs?
Submitted: Tuesday, Apr 29, 2003 at 22:43
ThreadID: 4656 Views:2072 Replies:3 FollowUps:4
Am searching for a traction aid for 60 series cruiser diffs and have been told that a GQ LSD can be fitted to a cruiser gear set.Can anyone varify this?
Reply By: Dozer - Wednesday, Apr 30, 2003 at 09:11
doubt it, never heard that one b4. Not saying it cant be done, but never heard of it on the cruiser websites. Go an air locker from ARB, dont do the autolockers as i had some in a 60 before. :-(
AnswerID: 18797
Follow Up By: Offie - Wednesday, Apr 30, 2003 at 15:05
I currently have 60's, what bad experience did you have with autolockers?
FollowupID: 11751
Follow Up By: Dozer - Saturday, May 03, 2003 at 08:15
Hi Offie
I bought a locrite to fit in a factory lsd. (There are two types and this one is cheaper.) When taking off the steering wheel needed to be corrected one way, change gear, and the steering would go the otherway.
It was dangerous, the locrite locked into the side gears of the cruiser diff and there wasnt enough of them to ensure both axles would be locked when the power was put down.
It went in the front not long after. I then found that when i wanted to select 4wd and turn a corner it was too hard to turn. Ended up locking the rear air locker (now) and driving with the front locked but in 2wd until i needed the 4.
Once, was in 4wd and powered after a turn, the steering wheel snapped out of my hands and i ripped bark off a tree with the bullbar/siderail.
Awsome traction, but buy airlockers and stay in control.
Andrew Wollongong
FollowupID: 11951
Reply By: Pelly - Thursday, May 01, 2003 at 12:51
Hi Guy's, reading through here Doser mentioned Cruiser web sites. I haven't been able to find any can someone please help? I also have a 60 series any infomation to help keep it going as well as it is for as long as posible. For economic reasons I wont be replacing it for awhile it's a good one and I'd like to keep it that way.
AnswerID: 18890
Follow Up By: Dozer - Saturday, May 03, 2003 at 08:20
try these
offroadrigs.org
offroad.au.com
lcool.org
ih8mud.com
"landcruiser" in surfing search engine
Andrew Wollongong
FollowupID: 11952
Reply By: Rob from Cairns Offroad Training & Tours - Thursday, May 01, 2003 at 21:04
I had a white factory turbo 60 series and still the best 4wd I have owned A friend of mine runs a LSD in the front of his cruiser ute with no real problems. This is probably the most economical way to go. Cheers RobCairns Offroad Training & Tours
AnswerID: 18937
Follow Up By: Dozer - Saturday, May 03, 2003 at 08:05
Hi Rob,
seen you somewhere before??
Go the 12ht 60!
Andrew
FollowupID: 11949
