Posting pictures from Photobucket for dummies
Submitted: Wednesday, Jun 13, 2007 at 10:03
ThreadID: 46607 Views:2719 Replies:6 FollowUps:20
Well its my one gripe about this site. posting pictures is like a rocket launch compared to other sites (right time right weather right loaction etc)
Tried all I could last night to no avaail
- Whats the secret??
due to the compexity of posting pictures i have been putting trip reports on other sites as Photos say far more than 1000 words when it comes to trip reports
Reply By: flappa - Wednesday, Jun 13, 2007 at 10:10
Lets see if this works
AnswerID: 246525
Follow Up By: Member - Davoe (Nullagine) - Wednesday, Jun 13, 2007 at 10:18
Cool picture................... Although somewhat unhelpfull given the topic
FollowupID: 507347
Follow Up By: flappa - Wednesday, Jun 13, 2007 at 10:19
I wanted to make sure it worked before I said how I did it
FollowupID: 507348
Follow Up By: Member - Davoe (Nullagine) - Wednesday, Jun 13, 2007 at 10:26
Annnnnd - Will you share??
FollowupID: 507350
Follow Up By: flappa - Wednesday, Jun 13, 2007 at 10:29
The trick I find is to firstly copy the address of your piccy into your reply.
Then copy the Hyperlink below "For Images" into your reply.
Then cut and paste your piccie address into the Hyperlink between src=" & "> therefore replacing http . . .domain . . image path.
FollowupID: 507351
Follow Up By: flappa - Wednesday, Jun 13, 2007 at 10:30
Davoe, I have been TRYING to write up how to do it , for some time now. the problem is the reply's dont like having dummy addresses put in.
FollowupID: 507352
Follow Up By: Member - Davoe (Nullagine) - Wednesday, Jun 13, 2007 at 10:32
OK one question PB gives 3 addresses is it the top middle or bottom you use (It is the bottom for other sites)
FollowupID: 507353
Follow Up By: flappa - Wednesday, Jun 13, 2007 at 10:37
I actually dont use any of those , directly.
I open the piccie , and use "properties" and copy that.
I dont profess to be an expert of this , but this works for me
FollowupID: 507354
Follow Up By: flappa - Wednesday, Jun 13, 2007 at 10:38
FollowupID: 507355
Follow Up By: flappa - Wednesday, Jun 13, 2007 at 10:39
Just checked.
I just used the bottom one to add the piccy this time
FollowupID: 507356
Follow Up By: Member - Davoe (Nullagine) - Wednesday, Jun 13, 2007 at 11:15
Nope just says a run time error has occured - do you want to de - bug
probably something to do with this crappy work I net cafe
FollowupID: 507367
Reply By: ExplorOz Team - David - Wednesday, Jun 13, 2007 at 11:52
Davoe,
What is the link syntax provided by Photobucket is it something like [IMG] - Can you copy and paste the provided syntax and I will make it work.
AnswerID: 246545
Follow Up By: flappa - Wednesday, Jun 13, 2007 at 12:14
FollowupID: 507379
Follow Up By: ExplorOz Team - David - Wednesday, Jun 13, 2007 at 13:48
OK thanks I will add this to the new release I am working on so that this conversion will be part of the standard.
FollowupID: 507394
Follow Up By: Motherhen - Wednesday, Jun 13, 2007 at 23:10
Sounds good David. I tried photobucket once, and just got the address as per flappa above. Someone added something and got my picture to work. I haven't been game to try again, and was keen to open this thread to learn how to do it.
FollowupID: 507491
Reply By: Member - Brian (WA) - Wednesday, Jun 13, 2007 at 13:31
hi Davoe
If this works I use the middle one
AnswerID: 246564
Follow Up By: Member - Brian (WA) - Wednesday, Jun 13, 2007 at 13:35
Not that. If this one I copied the top Two
FollowupID: 507391
Follow Up By: Member - Brian (WA) - Wednesday, Jun 13, 2007 at 13:37
Back to square one
FollowupID: 507392
Follow Up By: Member - Brian (WA) - Wednesday, Jun 13, 2007 at 13:48
FollowupID: 507395
Follow Up By: tvl - Wednesday, Jun 13, 2007 at 18:06
checking
FollowupID: 507414
Reply By: Hairy - Wednesday, Jun 13, 2007 at 19:12
img src="http://
AnswerID: 246634
Follow Up By: Richard Kovac - Wednesday, Jun 13, 2007 at 21:15
i120.photobucket.com/albums/o168/Hairy_photos/Finke%202007/100_4486.jpg
FollowupID: 507462
Follow Up By: Richard Kovac - Wednesday, Jun 13, 2007 at 21:17
FollowupID: 507463
cool
FollowupID: 507465
Reply By: Doggy Tease - Wednesday, Jun 13, 2007 at 21:21
!MPG:6!
AnswerID: 246665
Reply By: Member - Borgy.. (SA) - Wednesday, Jun 13, 2007 at 21:44
!MPG:25!
AnswerID: 246668
