Steering column lock on 78 series landcruiser
Submitted: Wednesday, Jun 13, 2007 at 16:00
Max and Sue
G'day
We just come back from a
Simpson Desert crossing. Have done less than 50 kilometres in town, and lucky it did not happen in
the desert, now find that the steering column lock is jammed. Meant pushing the vehicle out of the garage into a cul de sac with no steering to help. Had to be towed to a Toyota dealer for replacement. They tell me it is not a common problem, but the tow truck driver said he has been called to
Arkaroola to bring back a LC, and that is not the only incident he has experienced. Who is telling the truth.
Reply By: Crackles - Wednesday, Jun 13, 2007 at 17:45
Well Toyota sure aren't! I had a similar issue on my 105 series except I was lucky enough to have it jam in the assesory position. This allows a small button to be pushed underneath the tumbler so that the whole thing can be removed. With a pair of pointy nose plyers you can then start the car although the key still needs to be in the vicinity so the engine imobilizer is deactivated. When I took
mine into Toyota they were talking hundreds of dollars to have the thing replaced so I took it to a Locksmith instead who repaired it for $30. He had already seen a dozen others from late model Cruisers & said it was becoming very common for vehicles around 5 years old. Having a bunch of keys & remotes swinging off the ignition key is the quickest way to wear them out but
mine only has a single tag so there is certainly yet another issue with the Cruiser.
Cheers Craig.........
HZJ105 Vic
246606
Reply By: Trev B - Thursday, Jun 14, 2007 at 14:17
My Lexus LX470 had the steering lock in the
Davenport Range NP on 4/6/07 in NT & Lexus advised there was no easy answer. Luckily they also advised what to do & that it was not easy. We got going 5 hours later with the help of tools & input from 3 strangers.
Locksmiths advise there are 2 types of problem.
1. Most common is wear on the key so that the lock does not recognise it. Very common in Holdens & now I have heard of many cases in Cruisers from 80 series on. This can be fixed by locksmiths.
2. My case, & probably yours, the shaft from the key switch to the steering lock & to the actual ignition switch breaks. This leaves the steering locked. The shaft is not sold as a separate piece so the whole assembly has to be replaced. Cost of the assembly for Lexus $243, Cruiser probably cheaper but is different I am told.
The shaft is alloy &
mine broke with no warning. I am told by locksmiths that it rarely breaks. Lexus have known of 2 other cases.
The assembly is clamped to the steering column by 2 shear bolts which must be drilled out to remove it & free the steering, then the ignition switch can be removed from the back of the assembly & operated with a screwdriver. The key part of the switch only satisfies the security & turns the shaft which operates everything else.
Happy traveling
246767
Follow Up By: Max and Sue - Thursday, Jun 14, 2007 at 17:57
Trev, Thanks for the reply. I've just picked
mine up. They still say its a very rare thing to happen. I'm glad it didn't happen in
the desert. Sounds like it would have been a major problem.
Max
507617
