Patrol engine speed
Submitted: Wednesday, Jun 13, 2007 at 18:46
Member - stefan P (NSW)
Evening all,
As I have the 2.8 GU, its no secret that it revs its tits off at Hwy speeds due to its hi or is it low Diff ratio's. The question I pose is what is the best way of bringing the revs down a bit at Hwy speed? I understand that acceleration would suffer, I plan on doing the exhaust and chip real soon $$$$ permitting.
I guess the options are
1. Bigger tyres
2. change to different diff ratios
3. change gear ratios
I guess I am looking for the best cost effective out come here, and any advice from people who have done similar or warnings about what I should avoid as I have never contemplated anything like this in the past.
Stefan (3200rpm at 120kp/h)
Reply By: madfisher - Wednesday, Jun 13, 2007 at 18:57
Mate I think you have already answered your own question, but bigger tyres are going to be your cheapest option but your speedo will read slow.
Cheers Pete
246630
Follow Up By: Member - stefan P (NSW) - Wednesday, Jun 13, 2007 at 19:01
I guess with the tyres I can easily change if I don't like the result.
Cheers Stefan
507424
Follow Up By: madfisher - Wednesday, Jun 13, 2007 at 19:15
On our 3lt Paj we went to 10rs, which geared it up a bit but it did take the sting out of her, especially when towing or loaded up
Cheers Pete
507433
Reply By: Robin Miller - Wednesday, Jun 13, 2007 at 21:02
Hi Stefan
Long advocated use of 255/85/16 (33.3in) tyres for Patrol as largest tyre without a wide tread, so don't suffer from problems associated with wides.
My 4800 GU is geared about the same as yours, you will notice less torque off the line and should have car tuned with those tyres already on.
Robin Miller
246662
Follow Up By: Member - stefan P (NSW) - Thursday, Jun 14, 2007 at 20:39
thanks Robin.....will consider
507673
Reply By: BennyGU - Thursday, Jun 14, 2007 at 11:24
What you might need to remember is that the 2.8 is based on the skyline RB series of straight six petrol engines. They love revs and the 2.8 is humming very nicely at 3200 though it gets a bit strained at 140+ (3600rpm+) for highway running.
If they do run with less revs they do run alot rougher as they are not designed for it, hence no bottom end torque. If you do fit bigger tires this will affect the already strained clutch as there will be more revs off the line to get the big bus moving. I have 285/75/R16s on my 2.8 at the moment and with it fully loaded and towing my 16 foot boat it still will move of the line with no slipping of the clutch but do it slowly.
The 3.0l run a 4.3 diff ratio, the 4.2 n/a diesel had 4.11 and the 4.2 turbo 3.9's. All should fit as the diff assembly is the same. I have been thinking of doing a power-up for a while (2.75"
Beaudesert S/S exhaust and Motsons Enhancer) to make them sandhills easier but $$$$$ and SWMBO .......... I do believe that Marks Adaptors have a kit to bring 5th gear to a 4.2lTD final drive ratio for those who have converted from the screamer to the truck motor. I do not see any problems with doing this to a 2.8 as there is bugger all difference between fifth and fourth anyway. This way you have the low gearing for off the line (the bottom end will improve very noticably with a few rectifications) and the long range sprint gear. From memory the 4.2TD sits on about 2500rpm for 110km/hr so a chipped/zorsted 2.8 would be sitting halfway between max torque and power points for some decent economy and pulling power.
I have noticed though that if I sit on 90-95 km it burns around 10-11l/100km but if I bump it above 110km/hr it can easily burn 16/l+.
Ben
246742
Follow Up By: Member - stefan P (NSW) - Thursday, Jun 14, 2007 at 20:40
thanks Ben....I like the idea of just changing 5th
Stefan
507674
