nl pajero wheel offset
Submitted: Wednesday, Jun 13, 2007 at 20:18
kcandco
I have a 97 nl pajero with 15 x 6 steel rims fitted and am considering fitting wider rims. I have read that toyota rims are different offset. I occasionally see rims in the local paper ie navara, mazda etc but am unsure if the offsets would be right. Can anyone give me some tips on what will fit and any pitfalls I should be aware of. I suspect i would also have to fit wheel arch flares due to the extra width. I was not wanting to go extreme ...probably 265/15 or similar.
thanks Kc
Reply By: Member - Vince B (NSW) - Wednesday, Jun 13, 2007 at 21:43
Hi Kc.
I had a set of 15x8 on myNL(had to fit flares).I sold them & went back to GLS pajero mags with 10R's.It was a nicer vehicle to steer with the smaller
wheels.
You could try a set of 16" mags(off later model pajero).
Regards.
Vince
246666
Reply By: Stu050 - Wednesday, Jun 13, 2007 at 22:56
G'day Kc,
I was running 15 x 7 on my NJ Paj.
The offset that you need is the Navara offset. 15 x 7 fit no worries and wheel arch flares are not needed.
246678
Reply By: kcandco - Friday, Jun 15, 2007 at 20:02
Thanks Vince and Stu did you have any wear/alignment problems with the wider tyres?
Kc
247130
Follow Up By: Member - Vince B (NSW) - Saturday, Jun 16, 2007 at 16:05
No problems with wear as I rotated the tyres every 10k. Just keep an eye on your wheel alignment especially if you get into some rough stuff.
Regards.
Vince
508097
